#2229: error in projection definition
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: pseudomercator
Comment (by vincent):
Replying to [comment:19 mlennert]:
> As discussed during the code sprint, the issue is because of the very
weird nature of this "projection" system [...]
I fully agree with these comments
> The most reasonable conclusion, however, was to not use this system at
all because of it's weird nature. Several official administrations forbid
its use...
Ok bu sooner or later, users may have to manage data in this "projection"
system, and they might be puzzled (angry) to see it does not work despite
a proper location definition via the epsg code.
> In the discussions, one idea that came up was to provide alternative
datum transformation parameters for this system, one on the sphere and one
on the wgs84 ellipsoid.
If there is no solution to automatically "patch" this issue, meanwhile we
could edit a wiki page describing a solution (like passing a proj.4 chain)
to the location's creation.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:20>
