[GRASS-dev] [GRASS GIS] #2229: error in projection definition
  Reporter: vincent | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.5
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: pseudomercator
Comment (by mlennert):
Replying to [comment:20 vincent]:
> Replying to [comment:19 mlennert]:
> > As discussed during the code sprint, the issue is because of the very
weird nature of this "projection" system [...]
> I fully agree with these comments
> > The most reasonable conclusion, however, was to not use this system at
all because of it's weird nature. Several official administrations forbid
its use...
> Ok bu sooner or later, users may have to manage data in this
"projection" system, and they might be puzzled (angry) to see it does not
work despite a proper location definition via the epsg code.
> > In the discussions, one idea that came up was to provide alternative
datum transformation parameters for this system, one on the sphere and one
on the wgs84 ellipsoid.
> If there is no solution to automatically "patch" this issue, meanwhile
we could edit a wiki page describing a solution (like passing a proj.4
chain) to the location's creation.
At this stage, I'm not sure what the solution would be. I created a
location with the proj.4 chain you gave:
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +wktext +no_defs <>
and then attempted to project a file from EPSG 31370 (Belgian Lambert
1972) to that location, but I got the following error:
WARNING: pj_transform() a échoué: failed to load datum shift file
ERROR: Unable to re-project vector map <rues@urbis> from <Belgique31370>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:21&gt;
