#2232: Add text to each animation slide based on the result of a query on a vector
layer
Reporter: bhlevca | Owner: grass-dev@…
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
I would need that the animation tool would be able to handle automated
text addition to each slide as opposed to manual addition of the same text
to all the slides
For example: We end up with a set of raster layers that were the result of
a succession of interpolations from a vector point layer such as in a
climate map.
* Each raster layer was created based on a value extracted from the
point layer.
* At the same time to each temperature value in the point vector layer
there is a corresponding text time stamp.
It would be helpful to be able to extract the string from the vector layer
corresponding to each slide and attach it at export time.
If a GUI feature would be too complex to build at least a hook that would
let a script do something to attach the text on each separate slide could
be a first step. The script itself would be responsible to extract the
text information. The GUI would only have to apply the text provided by
the script to each slide.
This would be useful to create a time lapse movie when we deal with
regular raster layers and not with space-time layers. Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2232>
