[GRASS-dev] [GRASS GIS] #2238: minor change in r.stream.segment syntax
Reporter: madi | Owner: grass-dev@…
Priority: minor | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: r.stream.segment | Platform: Unspecified
      Cpu: Unspecified |
Following the unification of syntax used within r.stream.* modules, in
r.stream.segment we overlooked to change the input option stream_raster
into stream_rast. Since it is now in core and i don't have writing access,
could someone kindly do that.
Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238&gt;
Component: Raster | Version: svn-trunk
      Cpu: Unspecified |
Changes (by neteler):
  * component: Default => Raster
Comment:
Done in r59509 (trunk) and r59510 (releasebranch_7_0).
BTW: the param description wording is a bit odd.
     in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_stm_opt->key = "stream_rast";
     in_stm_opt->description = _("Name of input streams mask raster map");
     in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_dir_opt->key = "direction";
     in_dir_opt->description = _("Name for input raster map with flow
direction");
and should perhaps be sync'ed to that of "direction" (in all modules).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238#comment:1&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:1 neteler]:
thanks
map");
direction");
yes; any template/example around there to facilitate
unification/harmonizing not only for r.stream.* but also for other
hydrologically oriented modules?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238#comment:2&gt;
      Cpu: Unspecified |
Comment(by madi):
Thanks
map");
direction");
Agreed. Something like: "Name for input raster map with stream network"
should do.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: r.stream.segment
  Platform: Unspecified | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:3 madi]:
should do.
Done in r59519 and r59520.
Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2238#comment:4&gt;
