[GRASS-dev] [GRASS GIS] #225: vdigit crashes on some GRASS vectors I try to edit
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
vdigit crashes on some GRASS vectors I try to edit. Attached is a sample.
Enter the location, mapset 'test' and:
1. in wxGUI add the vector map to layers list
2. right click on it > "Zoom to selected map"
3. right click on it > "Start editing"
4. don't do anything and quit: whole wxGUI crashes and error is printed on
the terminal:
GRASS_INFO_ERROR(8913,1): region for current mapset line 1: <n-s resol:
0.002179>
GRASS_INFO_ERROR(8913,1): run "g.region"
GRASS_INFO_END(8913,1)
Ticket URL: <http://trac.osgeo.org/grass/ticket/225&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords: vdigit, locale
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
  * keywords: => vdigit, locale
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
it's related to the locale's problem of Nviz extension
http://lists.osgeo.org/pipermail/grass-dev/2008-July/038708.html
Fixed in trunk, devbr6 -- r32076 and r32077.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/225#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: vdigit, locale
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/225#comment:2&gt;
