[GRASS-dev] [GRASS GIS] #2255: g.mlist warnings for layers found in other mapsets
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
g.mlist produces warnings for all layers in other mapsets with names
matching the search pattern, even if mapset is set (which should force it
to search in that mapset only)
This is on GRASS 7.1.svn (2014), in Linux (Ubuntu 13.10)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255&gt;
      Cpu: Unspecified |
Comment(by neteler):
Not sure what the issue is... here an example:
grass71 -c ~/grassdata/nc_spm_08_grass7/user2
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mlist rast
raster map(s) available in mapset <PERMANENT>:
aspect
basin_50K
elev_state_500m
elevation
elevation_shade
zipcodes
zipcodes_dbl
# now copy over "elevation" map as found in search path to
# current mapset:
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.copy rast=elevation,elevation
Copy raster <elevation@PERMANENT> to current mapset as <elevation>
# list again:
raster map(s) available in mapset <user2>:
WARNING: 'cell/elevation' was found in more mapsets (also found in
          <PERMANENT>)
WARNING: Using <elevation@user2>
elevation
aspect
basin_50K
boundary_county_500m
elev_state_500m
          <PERMANENT>)
elevation@PERMANENT
elevation_shade
facility
zipcodes_dbl
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mapsets -l
Available mapsets:
PERMANENT landsat neteler user1 user2
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mapsets -p
Accessible mapsets:
user2 PERMANENT
So it tells the user that the map "elevation" exists multiple times in
the search path ("Accessible mapsets")... Guess that's how it should be.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:1&gt;
Let me try to clarify with an example. Suppose I have two different mapsets, Ethiopia and Ethiopiabackup, each with a number of layers with the same name. Now, if I use (just selecting 1 layer to keep the example short):
g.mlist type=rast pattern=fireprob_rf1 mapset=Ethiopia
Gives me:
fireprob_rf1
raster map(s) available in mapset :
WARNING: ‘cell/fireprob_rf1’ was found in more mapsets (also found in )
WARNING: Using fireprob_rf1@Ethiopia
If I use
I get:
fireprob_rf1
fireprob_rf1@Ethiopiabackup
In both cases the warnings are redundant. In example one I am only interested in what is in the mapset Ethiopia, thus, no need to tell me similar layers are in the mapset Ethiopiabackup or that the ones in the mapset Ethiopia will be used (what does that mean anyway, the function is to list the names of the layers, not to use them in any way). In example two, I can see from the list of layers that there are layers with the same name that come from different mapset. No need to warn me again.
I don’t think those warnings were displayed in earlier grass 7.0 version and I just checked and they are certainly not in 6.4.
Cpu: Unspecified |
Not sure what the issue is… here an example:
aspect
basin_50K
elev_state_500m
elevation
elevation_shade
zipcodes
zipcodes_dbl
now copy over “elevation” map as found in search path to
current mapset:
Copy raster elevation@PERMANENT to current mapset as
list again:
WARNING: ‘cell/elevation’ was found in more mapsets (also found in
WARNING: Using elevation@user2
elevation
aspect
basin_50K
elev_state_500m
elevation@PERMANENT
elevation_shade
facility
zipcodes_dbl
Available mapsets:
Accessible mapsets:
user2 PERMANENT
So it tells the user that the map “elevation” exists multiple times in
the search path (“Accessible mapsets”)… Guess that’s how it should be.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:1>
      Cpu: Unspecified |
Comment(by wenzeslaus):
Copied from [http://lists.osgeo.org/pipermail/grass-
dev/2014-April/068356.html grass-dev]:
$ g.mlist type=rast pattern=fireprob_rf1 mapset=Ethiopia
fireprob_rf1raster map(s) available in mapset <Ethiopia>:
WARNING: 'cell/fireprob_rf1' was found in more mapsets (also found in
<Ethiopiabackup>)
WARNING: Using <fireprob_rf1 at Ethiopia>
fireprob_rf1
<Ethiopiabackup>)
WARNING: Using <fireprob_rf1@Ethiopia>
raster map(s) available in mapset <Ethiopiabackup>:
<Ethiopiabackup>)
It also seems that the warning is reported multiple times and that the
overall formatting is strange (e.g. the line `raster map(s) available in
mapset <Ethiopia>:` followed by `WARNING: ...`).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:2&gt;
      Cpu: Unspecified |
Comment(by hcho):
Fixed in r60261.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:3&gt;
Component: LibRaster | Version: unspecified
Keywords: g.mlist, d.rast.leg | Platform: Unspecified
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: => g.mlist, d.rast.leg
  * component: Default => LibRaster
Comment:
In relbranch7 I have the same issue with d.rast.leg:
GRASS 7.0.0svn (eu_laea):~ > d.rast.leg diff
WARNING: 'cell/diff' was found in more mapsets (also found in
          <modis_lst_europe>)
WARNING: Using <diff@modis_lst_reconstructed_europe_daily>
WARNING: 'cellhd/diff' was found in more mapsets (also found in
          <modis_lst_europe>)
          <modis_lst_europe>)
(many more)
It seems to be a more generic issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:4&gt;
Keywords: g.mlist, d.rast.leg, d.rast | Platform: Unspecified
      Cpu: Unspecified |
  * keywords: g.mlist, d.rast.leg => g.mlist, d.rast.leg, d.rast
Comment:
Replying to [comment:3 hcho]:
> Fixed in r60261.
(backported in r61040)
Glynn posted some comments here:
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069628.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:5&gt;
