GDAL
April 22, 2014, 6:36pm
1
#2259: some temporal modules have empty manual page
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: temporal | Platform: Unspecified
Cpu: Unspecified |
List of temporal modules with empty manual page:
* t.rast.out.vtk
* t.rast.to.rast3
* t.rast3d.extract
* t.rast3d.list
* t.rast3d.mapcalc
* t.rast3d.univar
* t.remove
* t.sample
* t.support
* t.topology
* t.unregister
* t.vect.db.select
* t.vect.export
* t.vect.extract
* t.vect.import
* t.vect.list
* t.vect.observe.strds
* t.vect.univar
* t.vect.what.strds
At least minimum info (description, example) should be added before
releasing GRASS7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
April 22, 2014, 6:37pm
2
Cpu: Unspecified |
Description changed by martinl:
Old description:
* t.rast.out.vtk
* t.rast.to.rast3
* t.rast3d.extract
* t.rast3d.list
* t.rast3d.mapcalc
* t.rast3d.univar
* t.remove
* t.sample
* t.support
* t.topology
* t.unregister
* t.vect.db.select
* t.vect.export
* t.vect.extract
* t.vect.import
* t.vect.list
* t.vect.univar
* t.vect.what.strds
releasing GRASS7.
New description:
* t.rast.out.vtk
* t.rast.to.rast3
* t.rast3d.extract
* t.rast3d.list
* t.rast3d.mapcalc
* t.rast3d.univar
* t.remove
* t.sample
* t.support
* t.topology
* t.unregister
* t.vect.db.select
* t.vect.export
* t.vect.extract
* t.vect.import
* t.vect.list
* t.vect.univar
* t.vect.what.strds
releasing GRASS7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:1> ;
GDAL
April 22, 2014, 8:27pm
3
Cpu: Unspecified |
Comment(by huhabla):
This is work in progress.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2259#comment:2> ;
GDAL
August 22, 2014, 12:56pm
4
Cpu: Unspecified |
Comment(by martinl):
Please could you update status, which manuals are still missing?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:3> ;
GDAL
September 4, 2014, 2:34am
5
Cpu: Unspecified |
Comment(by wenzeslaus):
Currently, the example in manual pages can use only generated data. The
issue is that there is no official sample dataset for temporal data.
Please see:
* http://lists.osgeo.org/pipermail/grass-dev/2014-April/068556.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:4> ;
GDAL
September 14, 2014, 2:48pm
6
Cpu: Unspecified |
Replying to [comment:4 wenzeslaus]:
Please see:
to update status:
http://grasswiki.osgeo.org/wiki/GRASS_Community_Sprint_Portland_2014#Manual_improvements
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:5> ;
GDAL
September 23, 2014, 8:19pm
7
Cpu: Unspecified |
Comment(by sbl):
Just updated status on:
Seems a mistake has slipped in into the manual page for t.rast3d.univar,
the description is identical to t.rast3d.list / t.vect.list...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:6> ;
GDAL
October 24, 2014, 7:27am
8
Cpu: Unspecified |
Comment(by neteler):
Note: The page temporal/temporalintro.html needs an update for the default
mapset in which the temporal DB is stored, as per #2258
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:7> ;
GDAL
November 23, 2014, 11:06pm
9
Cpu: Unspecified |
List of empty manual pages was reduced in r62871 and r62874 to:
* t.topology
* t.vect.db.select
* t.vect.extract
* t.vect.list
* t.vect.univar
* t.vect.what.strds
The introduction in temporal/temporalintro.html was updated in r62877 to
reflect the mapset specific temporal database location.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:8> ;
GDAL
December 26, 2014, 10:44pm
10
Cpu: Unspecified |
Luca Delucchi in collaboration with Soeren Gebbert updated the manual
pages significantly in r63363.
Backported in r63771.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:9> ;
GDAL
December 29, 2014, 11:58am
11
Type: task | Status: closed
Resolution: fixed | Keywords: temporal
Platform: Unspecified | Cpu: Unspecified
Changes (by lucadelu):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:9 neteler]:
With r63808 and r63809 all the temporal manual has description and at
least an example. More small improvements are required but I'm going to
close this ticket, reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:10> ;
