[GRASS-dev] [GRASS GIS] #2278: G__tempfile() lacks perror support
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: LibGIS | Version: svn-releasebranch70
Keywords: r.hants | Platform: Unspecified
      Cpu: Unspecified |
(The problem arises from r.hants Addon use, reported on grass-user)
Using r.hants (derived from r.series) on almost 600 raster
maps generates an "ERROR: no temp files available" on
Linux 64bit. The input maps have been registered with
r.external:
D2/3: G_file_name(): path = /home/user/grassdata/latlong/cloro/GDAL
/home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.6
/home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.7
/home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.8
/home/user/grassdata/latlong/cloro/.tmp/localhost.localdomain/12772.9
GRASS 7.1.svn (latlong_wgs84):~ >
For a better error message, perror() should be used:
in lib/gis/tempfile.c
char *G__tempfile(int pid)
     do {
     int uniq = G_counter_next(&unique);
     sprintf(name, "%d.%d", pid, uniq);
     G_file_name(path, element, name, G_mapset());
     while (access(path, F_OK) == 0);
We need to explain the error with perror() as done in
in lib/gis/mapset.c
     if (access(mapset, F_OK) != 0) {
     perror("access");
     G_fatal_error(_("MAPSET <%s> not available"), mapset);
Anyone able to modify the while() loop in lib/gis/tempfile.c
accordingly?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2278&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2278 neteler]:
Ideally, strerror() (or similar) should be used, and the string included
in the error message. Otherwise, the additional details will be omitted
from any logfile ($GIS_ERROR_LOG) or email message ($GRASS_ERROR_MAIL).
Except, strerror() isn't thread-safe (it returns a pointer to a static
buffer). POSIX.1-2001 specifies strerror_r(), which requires the caller to
supply a buffer. Windows doesn't have that, but it has strerror_s (same
functionality, different argument order). So we'd need configure checks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2278#comment:1&gt;
      Cpu: Unspecified |
Comment(by mmetz):
> Linux 64bit.
r.series with the same number of input maps should fail with the same
error. r.hants has been derived from r.series, and both modules have the
-z flag (Don't keep files open) which should avoid this problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2278#comment:2&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:2 mmetz]:
> > Linux 64bit.
Sorry, the -z flag does not help here because r.hants creates a new output
map for each input map, and these need to be kept open. For 600 input
maps, the hard limit of the number of open files is usually exceeded.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2278#comment:3&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 glynn]:
in
> the error message.
Done by mmetz in r60148 and related.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2278#comment:4&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:4 neteler]:
included in
> > the error message.
For robustness, errno should be copied to a local variable immediately
after the failed call, e.g.:
     fcb->null_fd = creat(tempname, 0666);
     if (fcb->null_fd < 0) {
         int err = errno;
         G_fatal_error(_("No temp files available: %s"), strerror(err));
Otherwise, it may be modified by an intervening call (specifically,
close() can modify errno).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2278#comment:5&gt;
