GDAL
1
#228: error printed to the terminal after executing command from wxGUI cmd line
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
1. start GRASS
2. enter a command in the wxGUI cmd line, press enter - on the terminal
you get:
(python:4518): Gtk-CRITICAL **: gtk_widget_event: assertion
`WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
Ticket URL: <http://trac.osgeo.org/grass/ticket/228>
GDAL
2
Reporter: msieczka | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
After recent changes in wxGUI goutput module are you still getting this
error message. (No error here, Debian GNU/Linux unstable, wxPython
2.8.8.1).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/228#comment:1>
GDAL
3
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by msieczka):
* status: assigned => closed
* resolution: => fixed
Comment:
The issue is gone in the current SVN develbranch6.
Ticket URL: <http://trac.osgeo.org/grass/ticket/228#comment:2>
