[GRASS-dev] [GRASS GIS] #2289: v.colors not working
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: v.colors | Platform: Linux
      Cpu: x86-64 |
I guess something is wrong with v.colors. I'm not able to colorize
anything, it does say it sets the corresponding color table, but then...
just grey...
v.colors map=soils_general@PERMANENT use=cat color=wave
d.mon wx0
d.vect soils_general
---> no colors, just grey polygons
v.colors map=firestations use=cat color=random
d.mon wx1
d.vect firestations icon=basic/circle size=12
---> all grey circles
It doesn't work from the gui either.
I'm using grass7.1.svn (r60164M) under fedora 20.
Best,
Vero
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.colors
  Platform: Linux | Cpu: x86-64
Changes (by hcho):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in r60225.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:1&gt;
Component: Default | Version: svn-trunk
Changes (by neteler):
  * version: unspecified => svn-trunk
  * milestone: 7.1.0 => 7.0.0
Comment:
Replying to [comment:1 hcho]:
> Fixed in r60225.
Please let's keep it open unless the backport is done
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:2&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: v.colors
  * status: closed => reopened
  * resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:3&gt;
Oh! I got it. Thanks, Markus.
  • status: closed => reopened
  • resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:3>
Comment(by mlennert):
> Fixed in r60225.
I can confirm that this fixes the issue, but how come that in
grass70release the same code (as before the change) seems to work, but not
in trunk ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:4&gt;
In 70release, we had
else if (!mapset || !*mapset)
mapset = G_find_file2(element, name, mapset);
but in trunk, r60149 replaced it with
and G_find_file2 hates an empty name.
Huidae
Fixed in r60225.
in trunk ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:4>
2014-05-13 20:06 GMT+02:00 Huidae Cho <grass4u@gmail.com>:
then we should discuss about backporting such change instead of quick
fixing in relbr70 (without explanation)... Martin
I agree. Maybe, Markus M has a better idea why we needed r60149?
On Tue, May 13, 2014 at 2:08 PM, Martin Landa <landa.martin@gmail.com> wrote:
fixing in relbr70 (without explanation)… Martin
AFAICT, the reason for the logic change is so that it doesn't print a
warning if the file simply doesn't exist.
The previous version would only call G_find_file2() if the mapset
couldn't otherwise be determined, i.e. the name was unqualified and no
mapset was given. If the mapset could be determined either from a
qualified name or a non-empty mapset parameter, a non-existent file
wouldn't be detected until the open() call failed.
The new version always calls G_find_file2() first, so open() should
never be called for a non-existent file (or one which is inaccessible
due to the current process lacking execute (search) permission on any
ancestor directory). So a failed open() would indicate something less
mundane than a missing file.
I'm assuming that some code used the functions for a combined "check
whether it exists, and if so, open it" function. If that's the case,
warning about non-existent files would be a nuisance.
I'm still not sure whether this behaviour is a good idea, or whether
we should always generate the warning and require callers to perform
an explicit G_find_* call if the file's existence is merely "useful"
rather than either "required" or at least "expected".
And none of this changes the fact that Vect_read_colors() was broken
prior to r60225, and is still broken now.
If a function has parameters which happen to be used as the various
components of a filename, code shouldn't assume that they're just
going to get glued together and that it doesn't matter about the
individual pieces.
It's still broken now because the first argument to Rast__read_colors
is supposed to be an "element name", not two directory names glued
together. That it happens to work as a coincidence of implementation
details doesn't make it correct (in fact, "happens to work as a
coincidence of implementation details" is pretty much the definition
of a "hack").
Given that the current prototype for Rast__read_colors() doesn't
actually support reading colours for a vector map (because of the
vector code using the <mapset>/vector/<map>/<element> layout rather
than <mapset>/<element>/<map>), the correct solution is to add a new
function which takes a FILE* and let Vlib deal with opening (and
closing) the file.
I think in the long term it would be better to change the raster directory structure such that raster and vector have the same mapset/(raster, vector)/mapname/element path. Then we would be able to move some useful element related functions from librast to libgis.
Huidae
On May 13, 2014 5:11 PM, “Glynn Clements” <glynn@gclements.plus.com> wrote:
AFAICT, the reason for the logic change is so that it doesn’t print a
warning if the file simply doesn’t exist.
couldn’t otherwise be determined, i.e. the name was unqualified and no
wouldn’t be detected until the open() call failed.
I’m assuming that some code used the functions for a combined “check
whether it exists, and if so, open it” function. If that’s the case,
I’m still not sure whether this behaviour is a good idea, or whether
an explicit G_find_* call if the file’s existence is merely “useful”
rather than either “required” or at least “expected”.
components of a filename, code shouldn’t assume that they’re just
going to get glued together and that it doesn’t matter about the
individual pieces.
It’s still broken now because the first argument to Rast__read_colors
is supposed to be an “element name”, not two directory names glued
details doesn’t make it correct (in fact, “happens to work as a
coincidence of implementation details” is pretty much the definition
of a “hack”).
Given that the current prototype for Rast__read_colors() doesn’t
vector code using the /vector// layout rather
than //), the correct solution is to add a new
closing) the file.
The main downsides are:
1. You lose the ability to access the data with older versions of
GRASS.
2. You're more likely to run into limits on the number of maps within
a mapset. IIRC, ext2/ext3 doesn't allow a directory to have more than
32000 subdirectories, whereas there's no practical limit to the number
of files. OTOH, given that raster maps invariably have a non-empty
cell_misc subdirectory, this is probably a moot point.
  1. We may need to break backward compatibility at some point to improve the data structure. As long as we keep the same file format, we could provide a tool to build old databases out of new ones.
  2. Good point and right, even now, cell_misc has subdirectories, not files. If we really want to have no limits on the number of maps, we could make the folder structure flat and have a fixed number of element directories and files inside them. I personally don’t like such a limitation like max 32,000 maps. Maybe, moving/renaming vector/cell_misc element files to the mapset directory is a better option. mapset/element/mapname
On Wed, May 14, 2014 at 5:18 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
    GRASS.
  2. You’re more likely to run into limits on the number of maps within
    a mapset. IIRC, ext2/ext3 doesn’t allow a directory to have more than
    32000 subdirectories, whereas there’s no practical limit to the number
Comment(by neteler):
Replying to [comment:4 mlennert]:
> > Fixed in r60225.
in trunk ?
Indeed - is a backport needed? Seems to work without in relbranch7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2289#comment:5&gt;
Comment(by hcho):
You should backport both r60149 and r60225, or none of them. At this
point, if we don't already have r60149 in relbranch7, I wouldn't backport
r60225 until we come up with a better solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2289#comment:6&gt;
Replying to [comment:6 hcho]:
By chance I backported that earlier today in r61437.
> I wouldn't backport r60225 until we come up with a better solution.
I'll leave that decision to you.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2289#comment:7&gt;
Comment(by hcho):
Backported in r61449.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2289#comment:8&gt;
  * status: reopened => closed
Comment:
Works fine now, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2289#comment:9&gt;
