#2293: MapSwipe query maps
Reporter: lucadelu | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: MapSwipe, query, wxGUI | Platform: All
Cpu: Unspecified |
I would like if should be possible to query both maps in MapSwipe. Until
now no query function is supported in MapSwipe
I added query functionality in r60290. It displays query results from both
windows together in one dialog since it was the easiest way to implement
it. The dialog could have 2 trees of query results but that would require
more changes.
Replying to [comment:1 annakrat]:
both windows together in one dialog since it was the easiest way to
implement it. The dialog could have 2 trees of query results but that
would require more changes.
Thanks Anna, it works perfectly.
I don't know if this feature should be backported to releasebranch 70. If
not please close this ticket as fixed.
Replying to [comment:2 lucadelu]:
If not please close this ticket as fixed.
Me neither. But I decided to backport (r60326) the querying so that it is
easier to maintain Map Swipe bugfixes in both branches.
