#2300: v.out.ogr: spatialite support not working
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: Vector | Version: svn-trunk
Keywords: v.out.ogr, spatialite | Platform: Linux
Cpu: x86-64 |
Hi, as noted on the grass-users ML,
http://lists.osgeo.org/pipermail/grass-user/2014-May/070328.html
I'm not able to get Spatialite export working from v.out.ogr. Seen on both
GRASS 6.x and latest trunk for debian/wheezy.
Loading the mapset into the qgis grass toolbox on the same machine and
saving from there works, so I think the system libraries are all ok (gdal
1.9.0).
for my test I'm trying the usgsgages vector map from the North Carolina
dataset. I've tried roadsmajor type=line and census_wake2000 type=area and
they give the same trouble.
v.out.ogr in=usgsgages dsn=usgsgages.sqlite \
format=SQLite type=point dsco='SPATIALITE=yes'
the error, reported for each point is:
ERROR 1: sqlite3_step() failed:
usgsgages.GEOMETRY violates Geometry constraint [geom-type or SRID not
allowed] (19)
In trunk it seems to be happening on line 128 of v.in.ogr's export_lines.c
(~788 in main.c for devbr6):
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
api ref:
http://www.gdal.org/ogr/ogr__api_8h.html#a301d319111285a47fe6cda6e079214f8
MarkusN pulled up some hints from the gdal ML:
http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036148.html [[BR]]
http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036152.html
where Even wrote:
> The driver takes responsibility of assigning the SRID automatically from
> the layer SRS. So the error is likely due to an attempt of inserting a
> geometry whose type doesn't match the layer geometry type. Spatialite
> is really strict on that: POLYGON != MULTIPOLYGON, and (perhaps I'm not
> sure) 2D != 2.5D
In the gdal-dev thread the solution was to pick the correct one
of OGR_G_SetPoint() vs. OGR_G_SetPoint_2D(), maybe that helps here?
the code seems suitably pointy, even if it is embedded in the "lines" part
of the code, but I wonder if 2D vs 3D definition is causing trouble?
Converting usgsgages to a 3D points map didn't help.
else if ((type == GV_POINT) ||
((type == GV_CENTROID) && (otype & GV_CENTROID))) {
Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
Points->z[0]);
from the partially created sqlite file created by v.out.ogr here's the
creation log:
$ echo "SELECT * from spatialite_history;" | sqlite3 usgsgages4.sqlite
1|spatial_ref_sys||table successfully created|2014-05-19
23:14:31|1|3.7.13|3.0.0-beta
2|geometry_columns||table successfully created|2014-05-19
23:14:31|2|3.7.13|3.0.0-beta
3|spatial_ref_sys||table successfully populated|2014-05-19
23:14:32|3|3.7.13|3.0.0-beta
4|usgsgages|GEOMETRY|Geometry [POINT,XY,SRID=40004] successfully
created|2014-05-19 23:14:33|3.7.13|3.0.0-beta
5|usgsgages|GEOMETRY|R*Tree Spatial Index successfully created|2014-05-19
23:14:34|3.7.13|3.0.0-beta
One thing I notice is that SRID 40004 is a custom one added at the
end of the spatial_ref_sys table, after four other custom ones from
Italy. I'm not sure if that is relevant or not.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2300>
