[GRASS-dev] [GRASS GIS] #231: r.li.index in 6.3.1 svn doesn't worl
Reporter: leolami | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Keywords: r.li | Platform: Linux
      Cpu: Unspecified |
If i create a rigth configuration file with r.li.setup (es. moving window)
and then I use r.li.shannon commands I have this error message:
GRASS 6.3.0svn (Toscana):~ > r.li.shannon map=uso_primavera_2005
conf=navacchio output=shannon --overwrite
Segmentation fault
WARNING: Can't open header file for [ in (null)]
CHILD[pid = 3613]: unable to open mask ... continue without!!!
CHILD[pid = 3612]: unable to open mask ... continue without!!!
CHILD[pid = 3611]: unable to open mask ... continue without!!!
CHILD[pid = 3610]: unable to open mask ... continue without!!!
GRASS 6.3.0svn (Toscana):~ > WARNING: Can't open header file for [ in
(null)]
CHILD[pid = 3609]: unable to open mask ... continue without!!!
CHILD[pid = 3608]: unable to open mask ... continue without!!!
CHILD[pid = 3607]: unable to open mask ... continue without!!!
CHILD[pid = 3606]: unable to open mask ... continue without!!!
CHILD[pid = 3605]: unable to open mask ... continue without!!!
CHILD[pid = 3604]: unable to open mask ... continue without!!!
Niccolò Rigacci, with the help of Markus Neteler, has recompiled GRASS and
now it works but there is ever somethings of wrong.
Niccolo can you explain what did you do and where do you think the problem
is?
Thank you
Leonardo
Ticket URL: <http://trac.osgeo.org/grass/ticket/231&gt;
#231: r.li.index in 6.3.1 svn doesn't work
Resolution: | Keywords: r.li
  Platform: Linux | Cpu: Unspecified
Changes (by leolami):
  * summary: r.li.index in 6.3.1 svn doesn't worl => r.li.index in 6.3.1
              svn doesn't work
Ticket URL: <http://trac.osgeo.org/grass/ticket/231#comment:1&gt;
Old description:
window) and then I use r.li.shannon commands I have this error message:
Segmentation fault
(null)]
and now it works but there is ever somethings of wrong.
problem is?
Thank you
Leonardo
New description:
Segmentation fault
(null)]
is?
Thank you
Leonardo
Comment (by neteler):
Please better define:
- Platform:[[BR]]
- CPU:[[BR]]
- there is ever somethings of wrong.
I suppose it's a Debian Linux?
Ticket URL: <http://trac.osgeo.org/grass/ticket/231#comment:2&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: r.li
Changes (by neteler):
  * status: new => closed
  * resolution: => worksforme
Comment:
No response, works for me... feel free to reopen with more information.
Ticket URL: <https://trac.osgeo.org/grass/ticket/231#comment:3&gt;
