#2311: PyGRASS points read from map are always 2D although they have z coordinate
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: pygrass | Platform: All
Cpu: Unspecified |
When I read a 3D vector map
from grass.pygrass.vector import VectorTopo
vect = VectorTopo('precip_30ynormals_3d')
vect.open()
for point in vect[:3]:
print point.is2D, point.z
gives
True None
True None
True None
I am not sure how to fix it. Temporary workaround is (when I know the map
is 3D):
Cpu: Unspecified |
Comment(by annakrat):
A similar problem: I create a line from 3D points and the line is 2D. The
same workaround as above works.
Cpu: Unspecified |
Comment(by zarch):
Replying to [ticket:2311 annakrat]:
> [snip]
ok should be fix in r60880, please test it and let me know.
Cpu: Unspecified |
It seems to work, thank you. Could you backport it before we close it? And
the fix for #2320 as well.
