#2314: output r.out.xyz
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: separator, pipe, r.out.xyz, r.stats | Platform: MSWindows 7
Cpu: All |
Comment(by hcho):
Replying to [comment:16 glynn]:
> It adds a few new ones, namely that Python scripts (which don't use
G_option_to_separator()) are now trying to use the literal string "pipe"
as a separator. E.g.
> $ echo "170.510125 -45.868537" | m.proj -i input=-
> WARNING: Invalid field separator, using 'p'
> -4813902.92p-9497864.79p0.00
> G_OPT_F_SEP is used in r.out.xyz, v.in.lines, r.tileset and m.proj.
> r.out.xyz shouldn't be a problem, as the option is simply being passed
through to r.stats.
> The other three all use the option value.
> v.in.lines and m.proj explicitly understand space, tab and comma
(although I'm not sure that they interpret tab correctly; they appear to
treat it as a synonym for space).
> r.tileset doesn't understand any of the names, interpreting the value
literally.
I overlooked that some scripts use answers literally. Their default answer
just happened to be "|", not "comma", or some other strings, so we didn't
notice this issue so far.
> Also, none of this changes the fact that there appears to be a bug
somewhere. There '''shouldn't''' be any problems with using a literal
vertical bar character. If there are such problems, they should be fixed,
not simply worked around so that we can pretend there isn't a problem.
I agree if it can be fixed. E.g., the user can use "|", not "pipe" in the
wxGUI console. The backtick issue was worked around because it couldn't be
fixed (?) in Windows.
> While there are valid reasons for supporting "separator=pipe" (e.g. not
forcing users to understand how quoting/escaping works in their preferred
shell),
That very reason was why I chose to add "pipe" and as a side effect, this
issue was partially "taken care of".
> if it results in the original problem being forgotten about, it may need
to be reverted until the problem is fixed.
What about implementing grass.option_to_separator and keeping this ticket
open until the original issue is fixed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:17>
