#2317: G7: t.* modules suboptimal flag name -h, change to -c
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Component: Temporal | Version: svn-releasebranch70
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The temporal modules use a suboptimal flag name (raising confusion
between -h versus --h). This affects several t.* modules:
currently:
-h Print the column names as first row
--h Print usage summary
IMHO it is better to invert this behaviour as to "-c" in v.db.select:
-c Do not include column names in output
unless there is a strong need to NOT put the column names by default
(which I think would be helpful for the user).
and wondering if -h is a mistake or not and then I remembered this ticket.
The reasons why I'm not sure are:
* `-c` as a column to *not* adding columns (general problem of many
flags)
* what should be the default, user friendly output or parseable output?
(consider e.g. g.mlist and g.list)
Anyway, I'm for the change. (I cannot do it now but I guess it is easy
once approved.)
Keywords: interface, flags | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
Please try r61071.
I have changed the -h flag into -s to suppress column name printing in
several modules. Hence, column names are printed by default. Exception is
t.list that now has a -c flag to print column names.
