[GRASS-dev] [GRASS GIS] #232: raster and vector mismatch in monitors
Reporter: hcho | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: display, monitor | Platform: Linux
      Cpu: x86-32 |
I used r.to.vect to convert a raster map to vector and displayed both of
them on a monitor. When the monitor is in the default size, I can see
slight mismatch along the boundaries of the two maps. For example,
d.mon[[BR]]
g.region rast=tmp[[BR]]
d.erase[[BR]]
r.to.vect input=tmp output=tmp feature=area[[BR]]
d.rast tmp[[BR]]
d.vect tmp type=boundary
If I zoom in a lot or make the monitor larger, I don't see this effect. My
guess is that conversion between raster and vector was OK, but scaling
coordinates (R_scaled_raster or something?) before actually displaying
them might cause this problem. In effect, PNG maps exported from the
monitor looks so ugly.
I'm attaching two figures (small and large monitors).
Any idea?
Ticket URL: <http://trac.osgeo.org/grass/ticket/232&gt;
Resolution: | Keywords: display, monitor
  Platform: Linux | Cpu: x86-32
Comment (by hamish):
see also trac #72.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/232#comment:1&gt;
  Reporter: hcho | Owner: grass-dev@…
      Type: defect | Status: closed
Component: Default | Version: svn-trunk
Resolution: worksforme | Keywords: display, monitor
Changes (by mlennert):
  * status: new => closed
  * resolution: => worksforme
Comment:
This is 5 years old and I cannot reproduce the problem with the wxgui, so
closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/232#comment:2&gt;
      Type: defect | Status: reopened
Changes (by hamish):
  * status: closed => reopened
  * resolution: worksforme =>
Comment:
The bug still exists, at least in GRASS 6. Play with "xmag".
Also a similar issue is visible in symbols, but that's different, this one
is to do with d.vect.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/232#comment:3&gt;
  Priority: major | Milestone: 6.4.4
Component: Default | Version: svn-releasebranch64
  * version: svn-trunk => svn-releasebranch64
  * milestone: 7.0.0 => 6.4.4
Comment:
Replying to [comment:3 hamish]:
Ok, I can see it in GRASS 6 release, but not in 7. Can you reproduce it in
7 ?
I'm changing the milestone and version of this bug to better reflect where
the issue is.
Ticket URL: <https://trac.osgeo.org/grass/ticket/232#comment:4&gt;
