[GRASS-dev] [GRASS GIS] #2324: v.to.rast: useless area warning on points-only maps
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-releasebranch70
Keywords: v.to.rast | Platform: Unspecified
      Cpu: Unspecified |
There is a small issue which confuses (new) users a lot:
# rasterizing a map with only points:
# GRASS 7.1.svn (nc_spm_08_grass7):~ >
v.info -t geodetic_pts | grep 'points\|areas'
points=29939
areas=0
# ... but there is an area related warning!:
v.to.rast input=geodetic_pts output=test use=attr attr=GDC_ID
WARNING: No areas selected from vector map <geodetic_pts>
Reading features...
  100%
Writing raster map...
  100%
Converted points/lines: 29939 of 29939
v.to.rast complete.
The issue is here:
vect2rast.c:
     Points = Vect_new_line_struct();
     if (use != USE_Z && use != USE_D && (ftype & GV_AREA)) {
         if ((nareas = sort_areas(&Map, Points, field, cat_list)) == 0)
             G_warning(_("No areas selected from vector map <%s>"),
                           vector_map);
but I don't know how to change the if() condition properly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324&gt;
      Cpu: Unspecified |
Comment(by annakrat):
It seems to me that the condition is ok. You get the warning because the
default value of type parameter is point,line and area. So you should
specify explicitly type=point to avoid the warning. To avoid the confusion
the type parameter could be required but then we need to type more which
is probably not what we want.
BTW, I wonder why there is no warning about lines as well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324#comment:1&gt;
      Cpu: Unspecified |
Comment(by hcho):
IMO, type=point,line,area means to select those types only if they are
valid type in the input map. If a map is point only, type=line,area should
be ignored and no warnings about areas should be printed.
int sort_areas(...)
     nareas = Vect_get_num_areas(Map);
     if (nareas == 0)
         return -1;
int vect_to_rast(...)
         if ((nareas = sort_areas(&Map, Points, field, cat_list)) >= 0) {
             if (nareas == 0)
                           vector_map);
             G_debug(1, "%d areas sorted", nareas);
         } /* else map with no areas */
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324#comment:2&gt;
      Cpu: Unspecified |
Comment(by hcho):
Maybe, even shorter:
     if (use != USE_Z && use != USE_D && (ftype & GV_AREA) &&
         if (nareas == 0)
                       vector_map);
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324#comment:3&gt;
      Cpu: Unspecified |
Comment(by neteler):
(Reported in http://lists.osgeo.org/pipermail/grass-
user/2014-June/070411.html)
Points-only patching with v.patch reports the confusing messages:
Intersections at borders will have to be snapped
Lines common between files will have to be edited
The header information also may have to be edited
Likely only the last message should be shown in case that no areas/lines
are present.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2324#comment:4&gt;
