#2327: r.diversity = Illegal areas disposition
Reporter: sands | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.diversity | Platform: MSWindows 7
Cpu: x86-64 |
When running r.diversity in GRASS GIS 7.1svn [60382] on Windows 7 64 (but
with Python 2.7 win32) I get ERROR: Illegal areas disposition
With Helmut Kudrnovsky's help, I commented out lines 147-149 and 272-275
in r.diversity.py to keep the conf file and check it's contents, which
appear fine:
conf_diversity_3.0:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.00631578947368|0.00569259962049
MOVINGWINDOW
I would appreciate any suggestions on what the error could be.
# CODE: Using nc_spm_08_grass7
g.gisenv set=DEBUG=1
g.region rast=lsat5_1987_10@landsat
r.diversity --verbose input=lsat7_2002_10@PERMANENT prefix=t
method=simpson,pielou
"""Results:
D1/1: G_find_raster2(): name=lsat7_2002_10@PERMANENT mapset=
D1/1: grass.script.core.start_command(): r.li.simpson
input=lsat7_2002_10@PERMANENT conf=conf_diversity_3.0
output=t_simpson_size_3.0
D1/1: G_find_raster2(): name=lsat7_2002_10 mapset=PERMANENT
D1/1: G_find_raster(): name=MASK mapset=landsat
D1/1: r.li.daemon pathSetup: [C:\Users\Sands\AppData\Roa
ming\GRASS7\r.li\conf_diversity_3.0]
D1/1: grass.script.core.start_command(): r.li.pielou
output=t_pielou_size_3.0
(Fri Jun 06 07:24:02 2014) Command finished (0 sec)"""
Ticket URL: <http://trac.osgeo.org/grass/ticket/2327>
