#2333: choose python interpreter during the GRASS installation on windows
Reporter: zarch | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: windows installer python interpreter | Platform: MSWindows 8
Cpu: All |
Using the Windows installer would be great to be able to choice which
python interpreter must be used by GRASS.
Suppose that we have already installed a python interpreter like
[https://code.google.com/p/pythonxy/ pythonxy], at the moment the GRASS
installer use is own python interpreter therefore if I want to use any
python packages from GRASS, like [http://www.scipy.org/ scipy] or
[http://pandas.pydata.org/ pandas] I have, some how, to install these
packages on the GRASS interpreter even if they are already present in
pythonxy.
Do you think that would be possible to add this point to the GRASS
installer? or It is not possible to add this option because GRASS must be
compiled using the new interpreter? where should I look to try to add this
option?
Any hints?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2333>
