[GRASS-dev] [GRASS GIS] #2337: t.list hangs on newly created temporal DB
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: Temporal | Version: svn-trunk
Keywords: t.list | Platform: Linux
      Cpu: Unspecified |
t.list hangs when used on a newly created temporal DB which is still
empty:
GRASS 7.1.svn (eu_laea):~ > t.list -h
D1/1: grass.script.core.start_command(): t.connect -c
D1/1: grass.script.core.start_command(): t.connect -pg
D1/1: grass.script.core.start_command(): g.gisenv -n
D1/1: Start messenger server
D1/1: Initiate the temporal database
D1/1: SQLDatabaseInterfaceConnection constructor
D1/1: Start C-interface server
... then it hangs. CTRL-C "helps":
^CProcess Process-2:
Process Process-1:
   File "/usr/lib64/python2.6/multiprocessing/process.py", line 232, in
_bootstrap
_bootstrap
     self.run()
     self.run()
   File "/usr/lib64/python2.6/multiprocessing/process.py", line 88, in run
     self._target(*self._args, **self._kwargs)
   File
"/usr/local/grass-7.1.svn/etc/python/grass/temporal/c_libraries_interface.py",
line 644, in c_library_server
   File
"/usr/local/grass-7.1.svn/etc/python/grass/pygrass/messages/__init__.py",
line 73, in message_server
     conn.poll(None)
KeyboardInterrupt
     functions[data[0]](lock, conn, data)
   File
line 65, in available_mapsets
     if libgis.G__mapset_permissions(mapset) > 0:
KeyboardInterrupt
   File "/usr/local/grass-7.1.svn/scripts/t.list", line 157, in <module>
     main()
   File "/usr/local/grass-7.1.svn/scripts/t.list", line 111, in main
     stds_list = tgis.get_dataset_list(type, ttype, columns, where,
order)
   File "/usr/local/grass-7.1.svn/etc/python/grass/temporal/list_stds.py",
line 73, in get_dataset_list
     mapsets = get_tgis_c_library_interface().available_mapsets()
   File
line 1088, in available_mapsets
     return self.client_conn.recv()
KeyboardInterrupt
Using strace:
strace t.list -h
stat("/grassdata/eu_laea/PERMANENT/tgis/sqlite.db", {st_mode=S_IFREG|0644,
st_size=159744, ...}) = 0
open("/grassdata/eu_laea/PERMANENT/tgis/sqlite.db", O_RDWR|O_CREAT, 0644)
= 3
fcntl(3, F_GETFD) = 0
fcntl(3, F_SETFD, FD_CLOEXEC) = 0
fstat(3, {st_mode=S_IFREG|0644, st_size=159744, ...}) = 0
lseek(3, 0, SEEK_SET) = 0
read(3, "SQLite format 3\0\4\0\1\1\0@ \0\0\0X\0\0\0\0"..., 100) = 100
fcntl(3, F_SETLK, {type=F_RDLCK, whence=SEEK_SET, start=1073741824,
len=1}) = 0
fcntl(3, F_SETLK, {type=F_RDLCK, whence=SEEK_SET, start=1073741826,
len=510}) = 0
fcntl(3, F_SETLK, {type=F_UNLCK, whence=SEEK_SET, start=1073741824,
len=1}) = 0
access("/grassdata/eu_laea/PERMANENT/tgis/sqlite.db-journal", F_OK) = -1
ENOENT (No such file or directory)
read(3, "SQLite format 3\0\4\0\1\1\0@ \0\0\0X\0\0\0\0"..., 1024) = 1024
lseek(3, 5120, SEEK_SET) = 5120
read(3,
"\r\0\0\0\1\0\376\0\0\376\3\305\0z\0z\0\0\0\0\0\0G\4\6\27[5\1\0in"...,
1024) = 1024
lseek(3, 6144, SEEK_SET) = 6144
read(3,
"\r\0\0\0\3\1\201\0\1\201\1\270\3\267\0014\0014\0\0\0\0\0\0\0\0\0\0\0\0\0\0"...,
1024) = 1024
read(3,
"\r\0\0\0\6\0\300\0\0\300\1G\1\312\2/\2\320\3q\3u\0\0\0\0\0\0\0\0\0\0"...,
1024) = 1024
lseek(3, 149504, SEEK_SET) = 149504
read(3,
"\r\0\0\0\5\1_\0\1_\1\352\2G\2\340\3y\3\212\0\203\0\0\0\0\0\0\0\0\0\0"...,
1024) = 1024
lseek(3, 157696, SEEK_SET) = 157696
read(3,
"\r\0\0\0\5\1\301\0\2+\2\256\3$\3\222\1\301\0\0\0\0\0\0\0\0\0\0\0\0\0\0"...,
1024) = 1024
fcntl(3, F_SETLK, {type=F_UNLCK, whence=SEEK_SET, start=0, len=0}) = 0
wait4(11171, 0x7fff6df96024, WNOHANG, NULL) = 0
write(7, "\0\0\0\t\200\2]q\1K\10a.", 13) = 13
read(7,
It is polling for something unknown...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337&gt;
      Cpu: Unspecified |
Comment(by huhabla):
I can not reproduce this behavior on my Ubuntu 12.04 64 Bit system:
GRASS 7.1.svn (nc_spm_08):~ > t.info -s
  +------------------- Temporal DBMI backend information
  | DBMI Python interface:...... sqlite3
  | Temporal database string:...
/home/soeren/grassdata/nc_spm_08/PERMANENT/tgis/sqlite.db
  | SQL template path:..........
/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/sql
  | tgis_db_version .......... 2
  | creation_time .......... 2014-06-29 20:23:20.576947
  | tgis_version .......... 2
GRASS 7.1.svn (nc_spm_08):~ > rm
GRASS 7.1.svn (nc_spm_08):~ > t.list -h
Creating temporal database:
Can you please give more information about the software environment?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:1&gt;
      Cpu: Unspecified |
Comment(by spareeth):
I am getting the same error with t.list, on a mapset with number of
temporal datasets.
Using compiled grass7.1 on Ubuntu 14.04 LTS , 64 bit machine.
Here is the contents of my mapset folder.
ls -lh /grassdata/eu_laea/sp_garda_MODSST/
total 2.7M
drwxr-xr-x 2 sajid gis 336K Jun 18 19:26 cats
drwxr-xr-x 2 sajid gis 336K Jun 18 19:26 cell
drwxr-xr-x 2 sajid gis 336K Jun 18 19:26 cellhd
drwxr-xr-x 8466 sajid gis 336K Jun 18 19:26 cell_misc
drwxr-xr-x 2 sajid gis 168K Jun 3 14:21 colr
drwxr-xr-x 2 sajid gis 168K Jun 18 19:26 fcell
drwxr-xr-x 2 sajid gis 336K Jun 18 19:26 hist
-rw-r--r-- 1 sajid gis 35 Jun 3 15:42 SEARCH_PATH
drwxr-xr-x 2 sajid gis 10 Jun 3 05:28 sqlite
drwxr-xr-x 2 sajid gis 30 Jun 16 14:48 tgis
-rw-r--r-- 1 sajid gis 168 Jun 18 19:21 VAR
-rw-r--r-- 1 sajid gis 325 Jun 16 12:20 WIND
[Raster MASK present]
GRASS 7.1.svn (eu_laea):/usr/local/src/grass7 > ls -lh
/grassdata/eu_laea/sp_garda_MODSST/tgis/
total 9.9M
-rw-r--r-- 1 sajid gis 9.9M Jun 18 19:26 sqlite.db
Here is details of existing temporal datasets in the same mapset.
sqlite> select * from tgis_metadata;
tgis_db_version|2
creation_time|2014-06-16 14:48:41.645453
tgis_version|2
sqlite> select * from strds_metadata;
annual_count_MODSST@sp_garda_MODSST|raster_map_register_c985e0825e79458dafd50c8208950adc|11|169.0|0.0|219.0|0.0|1000.0|1000.0|1000.0|1000.0||count
MODSST|obs count MODSST|# 2014-06-16 14:48:41
t.create output="annual_count_MODSST" type="strds"
     semantictype="mean" temporaltype="absolute" title="count MODSST"
     description="obs count MODSST" --o
# 2014-06-16 14:49:57
t.register -i input="annual_count_MODSST" type="rast"
     file="count_modsst.txt" start="2003-01-01" increment="1 years"
test@sp_garda_MODSST|raster_map_register_ee1246eeeae64bdbafdb47960ee305d5|||||||||||test|test|#
2014-06-17 13:32:00
t.create output="test" type="strds"
     semantictype="mean" temporaltype="absolute" title="test"
     description="test" --o
Tdaily_modis_sst@sp_garda_MODSST|raster_map_register_1d62ff9fb6d749e3b860e74582b2f75c|4018|2238.0|1102.0|45727.0|42647.0|1000.0|1000.0|1000.0|1000.0||daily
temperature from Mod sst raw|daily T from on modis sst raw|# 2014-06-18
18:55:25
t.create output="Tdaily_modis_sst" type="strds"
     title="daily temperature from Mod sst raw"
     description="daily T from on modis sst raw" --o
# 2014-06-18 18:59:29
t.register -i input="Tdaily_modis_sst" type="rast"
     file="filenames_mod_sst_raw_2003-2013.txt" start="2003-01-01"
     increment="1 days" --o
Tmean_seasonal_modis_sst@sp_garda_MODSST|raster_map_register_c26f830534a54fa4bed121e590b2cccf|44|14789.390244|1785.0|41666.0|34808.5|1000.0|1000.0|1000.0|1000.0|average|daily
18:59:31
t.rast.aggregate input="Tdaily_modis_sst"
     output="Tmean_seasonal_modis_sst" base="Tmean_seasonal_modis_sst"
     granularity="3 months" method="average"
     where="start_time >= 2003-01-01 and start_time < 2014-01-01 " --o
Tmean_annual_modis_sst@sp_garda_MODSST|raster_map_register_1d916c3f94684bb89e68e8879c5a55da|11|26488.379085|17702.714286|29135.294521|20913.766667|1000.0|1000.0|1000.0|1000.0|average|daily
19:00:05
     output="Tmean_annual_modis_sst" base="Tmean_annual_modis_sst"
     granularity="1 years" method="average"
Tmean_deg_summer_modis_sst@sp_garda_MODSST|raster_map_register_cb672539b4184d8895354d5ab410dc44|11|24.321675|18.935825|27.882229|22.964133|1000.0|1000.0|1000.0|1000.0||daily
19:00:20
t.rast.extract input="Tmean_seasonal_modis_sst"
     where="strftime( %m , start_time)= 07 "
     expression="(Tmean_seasonal_modis_sst * 0.000717184972) - 2"
     output="Tmean_deg_summer_modis_sst" base="Tmean_deg_summer_modis_sst"
     nprocs="4" --o
Tmean_deg_winter_modis_sst@sp_garda_MODSST|raster_map_register_38a34bcf8ef649c5aac0c01d8176acbc|11|8.606728|7.445736|10.870829|9.222654|1000.0|1000.0|1000.0|1000.0||daily
19:00:22
     where="strftime( %m , start_time)= 01 "
     output="Tmean_deg_winter_modis_sst" base="Tmean_deg_winter_modis_sst"
     nprocs="4" --o
Tdaily_modis_sst_hants@sp_garda_MODSST|raster_map_register_a25db159e0ef40268a21c4b6189afea8|4018|13552.926495|-7030.313965|55117.719349|37973.938564|1000.0|1000.0|1000.0|1000.0||daily
temperature from Mod sst hants|daily T from on modis sst hants|#
2014-06-18 19:21:07
t.create output="Tdaily_modis_sst_hants" type="strds"
     title="daily temperature from Mod sst hants"
     description="daily T from on modis sst hants" --o
# 2014-06-18 19:25:22
t.register -i input="Tdaily_modis_sst_hants"
     type="rast" file="filenames_mod_sst_hants_2003-2013.txt"
     start="2003-01-01" increment="1 days" --o
Tmean_seasonal_modis_sst_hants@sp_garda_MODSST|raster_map_register_486e2c47f714412caf1fa6a31bff5823|44|14919.961618|5379.516413|45305.797911|36157.819222|1000.0|1000.0|1000.0|1000.0|average|daily
2014-06-18 19:25:24
t.rast.aggregate input="Tdaily_modis_sst_hants"
     output="Tmean_seasonal_modis_sst_hants"
     base="Tmean_seasonal_modis_sst_hants" granularity="3 months"
     method="average"
Tmean_annual_modis_sst_hants@sp_garda_MODSST|raster_map_register_8e844b411ed54f8e80537c58508ce2b7|11|25236.554709|19846.125419|28924.264045|24954.117264|1000.0|1000.0|1000.0|1000.0|average|daily
2014-06-18 19:26:15
     output="Tmean_annual_modis_sst_hants"
     base="Tmean_annual_modis_sst_hants" granularity="1 years"
     method="average"
Tmean_deg_summer_modis_sst_hants@sp_garda_MODSST|raster_map_register_98da1449fb394111b61d931da7ce52eb|11|24.284032|21.462871|27.860518|23.931845|1000.0|1000.0|1000.0|1000.0||daily
2014-06-18 19:26:33
t.rast.extract input="Tmean_seasonal_modis_sst_hants"
     expression="(Tmean_seasonal_modis_sst_hants * 0.000717184972) - 2"
     output="Tmean_deg_summer_modis_sst_hants"
     base="Tmean_deg_summer_modis_sst_hants" nprocs="4" --o
Tmean_deg_winter_modis_sst_hants@sp_garda_MODSST|raster_map_register_9ae7825d4f574e59bd5035c36a0b3b29|11|8.700372|7.571384|10.890343|9.823787|1000.0|1000.0|1000.0|1000.0||daily
2014-06-18 19:26:35
     output="Tmean_deg_winter_modis_sst_hants"
     base="Tmean_deg_winter_modis_sst_hants" nprocs="4" --o
t.list -c hangs and forced to ctrl-c, giving the following error trace.
Process Process-2:
   File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in
_bootstrap
   File "/usr/local/src/grass7/dist.x86_64-unknown-linux-
gnu/scripts/t.list", line 157, in <module>
     main()
gnu/scripts/t.list", line 111, in main
order)
gnu/etc/python/grass/temporal/list_stds.py", line 73, in get_dataset_list
     self.run()
   File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 644, in
c_library_server
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 1088, in
available_mapsets
gnu/etc/python/grass/temporal/c_libraries_interface.py", line 65, in
available_mapsets
KeyboardInterrupt
KeyboardInterrupt
Process Process-1:
_bootstrap
     self.run()
gnu/etc/python/grass/pygrass/messages/__init__.py", line 73, in
message_server
     conn.poll(None)
KeyboardInterrupt
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:2&gt;
      Cpu: Unspecified |
Update:
Looks like the issue is with the nfs system of the cluster where the
mapset is stored. When the same mapset is copied to local machine, t.list
works without any problem.
Let me know of any more information required to debug this issue.
Sajid
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:3&gt;
Keywords: t.list,t.create | Platform: Linux
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: t.list => t.list,t.create
Comment:
Reporting again with hanging t.create: We run current GRASS 7.1.svn in the
office and mount /grassdata via NFS3 from our cluster frontend machine.
With strace we got an idea where the problem is. Note that the user is
not operating in the mapset "lexem_matteo" cited below nor is it in
the mapset search path but it simply exists in the same location which
we share among our group:
GRASS 7.1.svn (eu_laea): >
strace t.create output=Tdaily_modis_hants type=strds semantictype=mean
temporaltype=absolute title="daily temperature from Mod lst hants"
description="daily T from hants on modis lst"
getuid() = 10014
stat("/grassdata/eu_laea/lexem_matteo", {st_mode=S_IFDIR|0755,
st_size=4096, ...}) = 0
getuid() = 10014
getuid() = 10014
getuid() = 10014
getuid() = 10014
getuid() = 10014
^CTraceback (most recent call last):
   File "/usr/local/grass-7.1.svn/scripts/t.create", line 84, in <module>
     main()
   File "/usr/local/grass-7.1.svn/scripts/t.create", line 77, in main
     tgis.init()
   File "/usr/local/grass-7.1.svn/etc/python/grass/temporal/core.py",
line 593, in init
Process Process-1:
Process Process-2:
_bootstrap
_bootstrap
     self.run()
   File
line 65, in message_server
     self.run()
   File
line 769, in c_library_server
     conn.poll(None)
KeyboardInterrupt
     dbif = SQLDatabaseInterfaceConnection()
line 839, in __init__
     self.tgis_mapsets = get_available_temporal_mapsets()
line 439, in get_available_temporal_mapsets
     mapsets = c_library_interface.available_mapsets()
   File
line 1220, in available_mapsets
KeyboardInterrupt
   File
line 159, in _available_mapsets
     if libgis.G_mapset_permissions(mapset) > 0:
KeyboardInterrupt
The ID of the actual user is 10014.
PROBLEM:
The issue happens in line 142
lib/python/temporal/c_libraries_interface.py
function def _available_mapsets(lock, conn, data):
where a while loop is used. The issue is apparently caused by the fact
that in our current cluster setup, after reinstallation, the NFS
daemon doesn't properly map the user ID's to the local workstation in
the office where not all users are existing. While we have to fix
this, it should not lead to an endless loop:
Apparently libgis.G_mapset_permissions() does not behave properly for
this NFS case. It should be able to leave the while loop rather than
getting stuck there.
# example for one of our NFS mounted directories as seen on the office
workstation:
ls -la /grassdata/eu_laea/lexem_matteo
total 312
drwxr-xr-x 13 10012 gis 4096 Jan 17 16:09 .
drwxrwxr-x 125 1338 gis 16384 Feb 3 18:35 ..
-rw------- 1 10012 gis 122050 Jan 1 18:26 .bash_history
-rw-r--r-- 1 10012 gis 1949 Jan 17 16:09 .bashrc
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cats
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cell
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cellhd
drwxr-xr-x 19 10012 gis 20480 Dec 27 14:22 cell_misc
--> user IDs not transmitted, our problem, but
libgis.G_mapset_permissions() doesn't deal with it properly (or
def_available_mapsets()).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:4&gt;
      Cpu: Unspecified |
I tried to fix the while loop in c_libraries_interface.py (r64470) that
hopefully contribute to solve the problem.
Unfortunately i have no NFS setup to test it properly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:5 huhabla]:
Thanks! Initial tests with our NFS show that r64470 solves the endless
loop issue.
I'd suggest to backport it if no other side-effects occur.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:6&gt;
Priority: normal | Milestone: 7.0.1
Component: Temporal | Version: svn-releasebranch70
Keywords: t.list, t.create, NFS | Platform: Linux
      Cpu: Unspecified |
  * keywords: t.list,t.create => t.list, t.create, NFS
  * version: svn-trunk => svn-releasebranch70
  * milestone: 7.0.0 => 7.0.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:7&gt;
     Type: task | Status: new
      Cpu: Unspecified |
Changes (by spareeth):
* cc: spareeth (added)
  * type: defect => task
Comment:
Hi
The solution is not yet backported into GRASS 7.0.1
Can we have it done?
Thank you
Sajid
Ticket URL: <https://trac.osgeo.org/grass/ticket/2337#comment:8&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: t.list, t.create, NFS
  Platform: Linux | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:8 spareeth]:
Done in r65103 through backport of r64470. Closing ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:9&gt;
