[GRASS-dev] [GRASS GIS] #2340: Rename i.landsat.rgb
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.landsat.rgb | Platform: All
      Cpu: Unspecified |
Since i.landsat.rgb is not limited at all to be used with LANDSAT,
the module should be renamed to a more generic name.
Eg. i.rgb.balance?
This should happen before the 7.0.0 release.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340&gt;
Priority: blocker | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by neteler):
  * priority: critical => blocker
Comment:
more suggestions:
  * i.enhance?
  * i.colors.enhance? # may be confused with r.colors
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:1&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 neteler]:
> more suggestions:
> * i.enhance?
I like i.colors.enhance: it's clear about what it does. I don't really see
the danger of confusing with r.colors. And it leaves the door open for
adding other color enhancement methods into the script (like i.pansharpen
for fusion).
BTW: the man page says "It will work with any 8-bit RGB imagery set and
the script is easily modified to work with other datasets of greater band-
depth." Is the 8-bit limit still the case ? And if yes, if it is easy to
do, why not modify it to accept greater depths ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:2&gt;
      Cpu: Unspecified |
Comment(by neteler):
i.landsat.rgb renamed to i.colors.enhance in trunk in r61481
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:3&gt;
      Cpu: Unspecified |
  * priority: blocker => critical
Comment:
Replying to [comment:3 neteler]:
Backported to relbr7 in r61483.
If all ok, the ticket may be closed (no idea about the 8 bit question
above).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: i.landsat.rgb
  Platform: All | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2340#comment:5&gt;
