[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
Reporter: neteler | Owner: grass-dev@…
Priority: critical | Milestone: 7.0.0
Component: Raster | Version: svn-releasebranch70
Keywords: | Platform: All
      Cpu: Unspecified |
At time, integer maps (CELL) are still compressed with RLE
This leads to a huge waste of disk space when it comes to large
data.
Proposal: make ZLIB, level 3 the standard compression.
At time we can enable the environment variable GRASS_INT_ZLIB
but it will use the default ZLIB level 6 compression which
is too CPU intensive. So a (user) control over this is important.
BTW: Manual of r.compress updated in r60814, needs to be backported.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349&gt;
      Cpu: Unspecified |
Comment(by neteler):
default ZLIB compression (usually 6), is hardcoded in:
lib/gis/flate.c, line 330
However, the used compression is yet RLE.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:1&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2349 neteler]:
> data.
Is GRASS_INT_ZLIB support now old enough that it can be taken for granted?
The current behaviour is that setting GRASS_INT_ZLIB to anything (even an
empty string) will enable zlib compression at the hard-coded level. One
option is to parse the value as an integer and use the result as the
compression level. However, it's possible that people are currently using
e.g. GRASS_INT_ZLIB=1 to enable it with the existing default level.
Another option is to add another environment variable for the level.
Aside: if there are still systems out there using the historical limit of
4096 bytes of memory for the combination of environment variables and
arguments (argv), we might want to think about making GRASS less greedy
with respect to environment variables.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:2&gt;
      Cpu: Unspecified |
Replying to [comment:2 glynn]:
> > data.
granted?
I hope yes. I am not aware of negative reports.
an empty string) will enable zlib compression at the hard-coded level.
Exactly.
> One option is to parse the value as an integer and use the result as the
Yes, a new GRASS_ZLIBLEVEL may be less invasive.
of 4096 bytes of memory for the combination of environment variables and
You mean the number and/or the length?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:3&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:3 neteler]:
Mainly the number.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:4&gt;
      Cpu: Unspecified |
Comment(by glynn):
r61380 implements the following behaviour:
  * zlib compression is the default. Set GRASS_INT_ZLIB=0 to use RLE
compression.
  * The compression level can be set via GRASS_ZLIB_LEVEL, whose value
should be an integer between 0 and 9. If not set (or if the value cannot
be parsed as an integer), zlib's default compression level will be used
(lib/gis/flate.c:333, if a different default is preferred).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:5&gt;
      Cpu: Unspecified |
Putting here to not forget about: raster/r.compress/r.compress.html needs
to be updated
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:6&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:6 neteler]:
> raster/r.compress/r.compress.html needs to be updated
Done in r61500.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:7&gt;
Keywords: compression | Platform: All
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: => compression
Comment:
In case of a backport to relbr7, this should be the needed changes:
r61380 + r61420 + r61422 + r61500
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:8&gt;
Priority: blocker | Milestone: 7.0.0
      Cpu: Unspecified |
  * priority: critical => blocker
Comment:
Any objections to backport?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:9&gt;
      Cpu: Unspecified |
Replying to [comment:5 glynn]:
In relbranch7 there is currently:
Z_DEFAULT_COMPRESSION = 1 - "gives the best compromise between speed and
compression" as per r61424.
Perhaps zlib compression 1 should be adopted for trunk?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:10&gt;
Keywords: compression, r.compress | Platform: All
      Cpu: Unspecified |
  * keywords: compression => compression, r.compress
Comment:
Replying to [comment:8 neteler]:
Backported to relbr7 in r61797.
Remains open which default ZLIB level should be used, see comment:10
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:11&gt;
      Cpu: Unspecified |
It seems that the NULL file is not compressed (file "cell_misc/null").
According to
http://lists.osgeo.org/pipermail/grass-user/2010-January/054216.html
it is one bit (null/non-null) for each cell. It looks like this:
[neteler@giscluster modis_lst_reconstructed_europe_daily]$ hexdump
cell_misc/lst_2002_196_average/null | head
0000000 ffff ffff ffff ffff ffff ffff ffff ffff
0000ad0 ffff ffff ffff ffe0 ffff ffff ffff ffff
0000ae0 ffff ffff ffff ffff ffff ffff ffff ffff
00015a0 ffff ffff ffff ffff ffff ffff e0ff ffff
00015b0 ffff ffff ffff ffff ffff ffff ffff ffff
0002080 ffff ffff ffe0 ffff ffff ffff ffff ffff
0002090 ffff ffff ffff ffff ffff ffff ffff ffff
For our 12829 daily min/average/max MODIS LST maps covering Europe, the
null files
consume a lot of space:
[neteler@giscluster cell_misc]$ du -hs .
621G .
Question: Would it be possible to compress also the null files, even with
just a
weak compression?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:12&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:12 neteler]:
According to
with just a
> weak compression?
Being uncompressed, the null files don't contain an index. The offset to
the beginning of a given row is obtained by multiplying the row number by
the number of bytes per row (which is just the number of columns divided
by 8, rounded upwards).
The main issue is likely to be the need to support both formats. We need
to
  * Be able to read and write the uncompressed format, for compatibility
with existing versions of GRASS.
  * Be able to distinguish between compressed and uncompressed formats on
read.
  * Provide some mechanism (i.e. yet another environment variable) to
indicate which format to use on write.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:13&gt;
Priority: critical | Milestone: 8.0.0
Component: Raster | Version: svn-trunk
      Cpu: Unspecified |
  * priority: blocker => critical
  * version: svn-releasebranch70 => svn-trunk
  * milestone: 7.0.0 => 8.0.0
Comment:
Replying to [comment:13 glynn]:
to
... at this point raster format changes may go into GRASS GIS 8.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:14&gt;
Priority: critical | Milestone: 7.1.0
Keywords: compression, r.compress, null | Platform: All
      Cpu: Unspecified |
  * keywords: compression, r.compress => compression, r.compress, null
  * milestone: 8.0.0 => 7.1.0
Comment:
back to this topic: Here on our system I found > 1.7TB of NULL files in a
single location, all
uncompressed.
What about having a "null2" file which is compressed and with index. If
present, fine, otherwise use the uncompressed well known null file format?
For backward compatibility, r.null could extended to convert from
compressed null2 to
uncompressed null (similar to v.build for the new spatial index in G7).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:15&gt;
Resolution: | Keywords: compression, r.compress, null
       CPU: Unspecified | Platform: All
Comment (by glynn):
Replying to [comment:15 neteler]:
a single location, all
> uncompressed.
How large are the null files compared to the cell/fcell files?
That's probably not a great deal of work, but as with any such change, we
need to consider the migration strategy. If we just start creating
compressed null files, mapsets will cease to be usable with older
versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:16&gt;
Comment (by neteler):
Replying to [comment:16 glynn]:
  * With MODIS LST data, the null files are between 1.7 and 7.6 times
larger than the cell files (we store the LST maps in deg C * 100 as
integer to save disk space).
  * With 100k random points, the null file is 7.1 times larger than the
fcell map
  * With the EU 25m DEM, the null file is way smaller that the derived
aspect map (17% of the DEM fcell file)
If present, fine, otherwise use the uncompressed well known null file
format?
we need to consider the migration strategy. If we just start creating
versions.
Right but this could be covered with an addon/new script in G6 and earlier
(as v.build does for vector data).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:17&gt;
Changes (by glynn):
* Attachment "compressed_nulls.diff" added.
implement compressed nulls
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349&gt;
Comment (by glynn):
Please test attachment:compressed_nulls.diff
Note that r.null and r.support will also require some changes, as they
assume that the file consists of nothing but the null data (i.e. no
index).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:18&gt;
