#2350: G7: r.texture large file support problem
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: unspecified
Keywords: LFS, r.texture | Platform: Linux
Cpu: x86-64 |
There seems to be a large file support issue under certain (?)
circumstances:
# Scientific Linux, 64bit:
# region size: 156044800 cells
r.texture input=pca_43140.1 prefix=pca_43140.1 \
size=9 distance=1 method=asm,se,var
Reading raster map...
Calculating 3 texture measures
WARNING: Unable to rename null file
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.1' to
'/grassdata/patUTM32/alba_classification/cell_misc/x43140_2006_pca.1_ASM/null'
WARNING: Unable to rename cell file
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.0' to
'/grassdata/patUTM32/alba_classification/fcell/x43140_2006_pca.1_ASM'
WARNING: Unable to write quant rules: raster map <x43140_2006_pca.1_ASM>
is
integer
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.3' to
'/grassdata/patUTM32/alba_classification/cell_misc/x43140_2006_pca.1_Var/null'
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.2' to
'/grassdata/patUTM32/alba_classification/fcell/x43140_2006_pca.1_Var'
WARNING: Unable to write quant rules: raster map <x43140_2006_pca.1_Var>
is
integer
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.5' to
'/grassdata/patUTM32/alba_classification/cell_misc/x43140_2006_pca.1_SE/null'
'/grassdata/patUTM32/alba_classification/.tmp/blade21/2161.4' to
'/grassdata/patUTM32/alba_classification/fcell/x43140_2006_pca.1_SE'
WARNING: Unable to write quant rules: raster map <x43140_2006_pca.1_SE> is
integer
Result (failure):
r.info x43140_2006_pca.1_ASM
| Layer: x43140_2006_pca.1_ASM Date: Tue Jun 24 17:17:35 2014
| Mapset: alba_classification Login of Creator: lucadelu
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 11680
| Columns: 13360
| Total Cells: 156044800
| Projection: UTM (zone 32)
| N: 5124056.897747 S: 5118216.897747 Res: 0.5
| E: 667131.354793 W: 660451.354793 Res: 0.5
| Range of data: min = -2147483648 max = -2147483648
Using a different machine, it worked fine:
# Ubuntu 14 64 bit machine:
GRASS 7.0.0svn (Trento-landchange):~ > r.info pca_43140.1_ASM
| Layer: pca_43140.1_ASM Date: Wed Jun 25 15:04:01 2014
| Title: ( pca_43140.1_ASM )
| Data Type: FCELL
| Rows: 11680
| Columns: 13360
| Range of data: min = 0.00737847 max = 1
I am not sure what to look for now, suggestions?
Is r.texture supporting LFS?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2350>
