[GRASS-dev] [GRASS GIS] #2352: Conflicting definitions of db__driver_describe_table
  Reporter: hamish | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 6.4.6
Component: Database | Version: 6.4.3
Resolution: | Keywords: dbf driver, libdb
       CPU: All | Platform: All
Comment (by neteler):
Travis-CI shows now some issues:
(cd /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/lib; ln
-f -s libgrass_dbmibase.7.1.svn.so /home/travis/build/GRASS-GIS/grass-
ci/dist.x86_64-pc-linux-gnu/lib/libgrass_dbmibase.so)
if [ "" != "" -a -f "".html ] ; then make html ; fi
make[4]: Leaving directory `/home/travis/build/GRASS-GIS/grass-
ci/lib/db/dbmi_base'
make -C dbmi_client || echo /home/travis/build/GRASS-GIS/grass-
ci/lib/db/dbmi_client >> /home/travis/build/GRASS-GIS/grass-ci/error.log
make -C stubs || echo /home/travis/build/GRASS-GIS/grass-ci/lib/db/stubs
make[4]: Entering directory `/home/travis/build/GRASS-GIS/grass-
ci/lib/db/stubs'
test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
ci/lib/db/dbmi_client'
gcc -g -O2 -fPIC -I/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64
-pc-linux-gnu/include -I/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64
-pc-linux-gnu/include -DPACKAGE=\""grasslibs"\" -I/home/travis/build
/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/include -I/home/travis/build
-DRELDIR=\"lib/db/stubs\" -o OBJ.x86_64-pc-linux-gnu/add_col.o -c
add_col.c
-pc-linux-gnu/include -I../dbmi_base -DPACKAGE=\""grasslibs"\"
-I/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/include
-DRELDIR=\"lib/db/dbmi_client\" -o OBJ.x86_64-pc-linux-gnu/c_add_col.o -c
c_add_col.c
add_col.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
compilation terminated.
gnu/c_list_drivers.o -c c_list_drivers.c
d_error.c: In function ‘db_d_append_error’:
d_error.c:78:11: warning: ignoring return value of ‘fread’, declared
with attribute warn_unused_result [-Wunused-result]
-DRELDIR=\"lib/db/dbmi_client\" -o OBJ.x86_64-pc-linux-gnu/select.o -c
select.c
gcc -shared -o /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-
gnu/lib/libgrass_dbmidriver.7.1.svn.so -L/home/travis/build/GRASS-GIS
/grass-ci/dist.x86_64-pc-linux-gnu/lib -L/home/travis/build/GRASS-GIS
/grass-ci/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-
link,/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/lib
-Wl,-soname,libgrass_dbmidriver.7.1.svn.so OBJ.x86_64-pc-linux-
gnu/d_add_col.o OBJ.x86_64-pc-linux-gnu/d_bindupdate.o OBJ.x86_64-pc-
linux-gnu/d_close_cur.o OBJ.x86_64-pc-linux-gnu/d_closedb.o OBJ.x86_64-pc-
linux-gnu/d_createdb.o OBJ.x86_64-pc-linux-gnu/d_create_idx.o OBJ.x86_64
-pc-linux-gnu/d_create_tab.o OBJ.x86_64-pc-linux-gnu/d_delete.o OBJ.x86_64
-pc-linux-gnu/d_deletedb.o OBJ.x86_64-pc-linux-gnu/d_desc_table.o
OBJ.x86_64-pc-linux-gnu/d_drop_col.o OBJ.x86_64-pc-linux-
gnu/d_drop_index.o OBJ.x86_64-pc-linux-gnu/d_drop_tab.o OBJ.x86_64-pc-
linux-gnu/d_error.o OBJ.x86_64-pc-linux-gnu/d_execute.o OBJ.x86_64-pc-
linux-gnu/d_fetch.o OBJ.x86_64-pc-linux-gnu/d_finddb.o OBJ.x86_64-pc-
linux-gnu/d_insert.o OBJ.x86_64-pc-linux-gnu/d_listdb.o OBJ.x86_64-pc-
linux-gnu/d_list_idx.o OBJ.x86_64-pc-linux-gnu/d_list_tabs.o OBJ.x86_64
-pc-linux-gnu/d_mkdir.o OBJ.x86_64-pc-linux-gnu/d_opendb.o OBJ.x86_64-pc-
linux-gnu/d_openinsert.o OBJ.x86_64-pc-linux-gnu/d_openselect.o OBJ.x86_64
-pc-linux-gnu/d_openupdate.o OBJ.x86_64-pc-linux-gnu/d_priv.o OBJ.x86_64
-pc-linux-gnu/driver.o OBJ.x86_64-pc-linux-gnu/driver_state.o OBJ.x86_64
-pc-linux-gnu/d_rows.o OBJ.x86_64-pc-linux-gnu/d_update.o OBJ.x86_64-pc-
linux-gnu/d_version.o -lgrass_dbmibase.7.1.svn -lgrass_dbstubs.7.1.svn
-lgrass_gis.7.1.svn -lm
/usr/bin/ld: cannot find -lgrass_dbstubs.7.1.svn
collect2: ld returned 1 exit status
The first issue will cause the third (and the second is "just" a warning).
Interestingly, changing into lib/db/stubs/ and running make on my local
machine for a second time resolved it. Probably only a Makefile issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2352#comment:6&gt;
