GDAL
June 26, 2014, 5:09pm
1
#2353: v.univar says type not supported instead of column does not exist
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: trivial | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Keywords: v.univar, vector, messages | Platform: All
Cpu: Unspecified |
G7:v.univar with column which does not exists reports low-level message
"no such column" tow times together with some other things and than gives
GRASS standard error "Column type not supported". It should end after the
first try, not print the low-level (detailed) messages (if possible,
should go to debug), and print the correct error message ""Column does not
exist" (or "not found"?).
v.univar map=bridges column='YEAR_BUILTTT'
DBMI-SQLite driver error:
Error in sqlite3_prepare():
SELECT cat, YEAR_BUILTTT FROM bridges
no such column: YEAR_BUILTTT
ERROR: Column type not supported
I was not looking to the source code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2353> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
July 8, 2015, 2:49am
2
Resolution: | Keywords: v.univar, vector, messages
CPU: Unspecified | Platform: All
Comment (by jrobparsons):
Can not duplicate.
GIS GRASS 7.1.SVN
Build Date: 2015-07-03
Python: 2.7.4
wxPython: 2.8.12.1
Windows 7
(Tue Jul 07 22:01:45 2015)
v.univar map=bridges column=YEAR_BUILTTT
ERROR: Column <YEAR_BUILTTT> not found in table <bridges>
(Tue Jul 07 22:01:47 2015) Command finished (2 sec)
GIS GRASS 7.1.SVN (64bit)
Build Date: 2015-06-25
Python: 2.7.6
wxPython: 2.8.12.1
Ubuntu 14.04 LTS
(Tue Jul 7 22:15:39 2015)
(Tue Jul 7 22:15:40 2015) Command finished (0 sec)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2353#comment:1> ;
GDAL
July 8, 2015, 3:29am
3
Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.univar, vector, messages
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
I can't reproduce it either:
> v.univar map=hospitals column='ANGLE'
minimum: 0
maximum: 1
range: 1
sum: 133
> v.univar map=hospitals column='XXX'
ERROR: Column <XXX> not found in table <hospitals>
I searched logs ([https://trac.osgeo.org/grass/log/grass/trunk/lib/db db
lib] and [https://trac.osgeo.org/grass/log/grass/trunk/vector/v.univar
v.univar]) and it was fixed in r63889 by martinl (backported in r63891).
Thanks, Martin!
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2353#comment:2> ;
