[GRASS-dev] [GRASS GIS] #2357: r3.info segfaults or reports incorrect values on Windows
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster3D | Version: svn-releasebranch70
Keywords: r3.info | Platform: MSWindows 8
      Cpu: Unspecified |
When I run r3.info on Windows on a map computed with v.vol.rst, it's
segfaults and stops writing output after:
  | Projection: Lambert Conformal Conic (zone 0)
  | N: 100 S: 0 Res: 1
  | E: 100 W: 0 Res: 1
When I create a random map:
g.region w=0 e=100 s=0 n=100 t=100 b=0 res=1 res3=1
r3.mapcalc "test = rand(0,100)"
it doesn't segfault but I get nonsense (I guess it's the same problem):
| N: 100 S: 0 Res: 1
| E: 100 W: 0 Res: 1
| T: 0 B: 0 Res: 0
| Range of data: min = 0 max = 0
The same map copied to linux has no problems. Perhaps the function
`format_double` could cause it since it is used for reporting top, bottom
and range values.
Further investigation shows that r.info reports wrong number of categories
(0) on a map which has categories. This would again point at
`format_double` function which looks completely the same as in r3.info.
However, v.info seems to work although it uses again `format_double`
function, but slightly modified:
r(3).info:
void format_double(const double value, char *buf)
     sprintf(buf, "%.8lf", value);
     G_trim_decimal(buf);
v.info:
void format_double(double value, char *buf)
     sprintf(buf, "%.8f", value);
Could the `l` in the formatting make difference on Windows?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2357&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
I seems that some C standards allow `l` to precede `f` but they also say
that `lf` is the same as `f`. From this it seems that on MS Windows,
because of MinGW or whatever, `lf` have unpredictable behavior. So, since
it is not different form `f` (both mean `double`), I suggest to replace
all occurrences of `lf` by `f`.
Also, the fact that there is more than `format_double()` function tells me
that it should be moved to the library. It might also avoid possibility of
bugs like this. The function looks pretty general, or at least, it is
used generally. Or do you think that these small functions should not go
to the library?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2357#comment:1&gt;
      Cpu: Unspecified |
Comment(by annakrat):
I removed the `l` from the function in !r3.info module to test if it makes
difference (r61172).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2357#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r3.info
  Platform: MSWindows 8 | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 annakrat]:
makes difference (r61172).
This fixed the problem. I applied it to r.info (r61189) and backported to
releasebranch (r61190) .
Ticket URL: <http://trac.osgeo.org/grass/ticket/2357#comment:3&gt;
