[GRASS-dev] [GRASS GIS] #2362: database connection for output of r.stream.snap
Reporter: jradinger | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Database | Version: unspecified
Keywords: | Platform: All
      Cpu: Unspecified |
The output of r.stream.snap in GRASS7.1 does not contain any database
(Sqlite) table by default. So when I want to browse the attribute table I
get the error message: "DB connection for vector map XXX not defined."
Then I can manually define a layer (from the initial input vector).
However I think that two layers should be created based on what is
mentioned in the manual.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2362&gt;
      Cpu: Unspecified |
Comment(by jradinger):
Here some minimum working example from the NC-dataset.
# Within NC-Dataset
# streams extract from elevation map via r.watershed
r.watershed elevation=elevation threshold=100 stream=rwatershed_streams
# Snap hospitals to rivers
r.stream.snap input=firestations output=firestations_snapped
stream_rast=rwatershed_streams radius=15
Ticket URL: <https://trac.osgeo.org/grass/ticket/2362#comment:1&gt;
Component: Addons | Version: svn-trunk
Keywords: r.stream.snap | Platform: All
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: => r.stream.snap
  * version: unspecified => svn-trunk
  * component: Database => Addons
Comment:
(r.stream.snap was moved back to Addons)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2362#comment:2&gt;
