[GRASS-dev] [GRASS GIS] #2378: t.list output lines mixed in wxGUI
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: temporal, t.list, stdout, stderr | Platform: Linux
      Cpu: Unspecified |
When I use `t.list` in wxGUI Command console or from the generated dialog
(form), I first get the section labels and then I get dataset names, so
dataset are not printed in the right sections (i.e. mapsets).
It works OK in the standard command line. First I think that the problem
is in GUI but it behaves nicely with `g.mlist` (can it be just a lucky
coincidence that it works?). So, I don't know.
For example:
t.list columns=id,name
gives:
Space time raster datasets with absolute time available in
mapset <climate_2000_2012>:
Space time raster datasets with relative time available in
mapset <NagsHead_series>:
precip_sum@climate_2000_2012|precip_sum
tempmean@climate_2000_2012|tempmean
tempmean_2010@climate_2000_2012|tempmean_2010
tempmean_F_summer@climate_2000_2012|tempmean_F_summer
tempmean_seasonal@climate_2000_2012|tempmean_seasonal
NagsHead_99_08@NagsHead_series|NagsHead_99_08
instead of (obtained in command line):
Space time raster datasets with absolute time available in mapset
Space time raster datasets with relative time available in mapset
<NagsHead_series>:
While
g.mlist -p type=rast
works as expected:
raster files available in mapset <NagsHead_series>:
NH_1999_1m NH_2002_1m_interp NH_2005_1m NH_2008_1m
NH_2000_1m_interp NH_2003_1m_interp NH_2006_1m_interp
NH_2008_1m_0.05
NH_2001_1m NH_2004_1m NH_2007_1m
raster files available in mapset <PERMANENT>:
elev_state_500m
By the way, now I also see that `t.list` lists all mapsets while `g.mlist`
just search path but this is for different ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2378&gt;
