[GRASS-dev] [GRASS GIS] #2380: d.legend "use" argument makes legend disappear
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Display | Version: svn-trunk
Keywords: d.legend | Platform: Unspecified
      Cpu: Unspecified |
If I put a list of values into d.legend use= , the legend disappears in
the GUI and the attribute GUI cannot be opened again. Not sure if this is
a d.legend problem, a GUI problem, or a combination.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
I find that you must put this list in quotes "7321, 7300,7100,7000,6955"
instead of 7321, 7300,7100,7000,6955 as indicated in the manual.
Unfortunately, this turns the legend into a series of discrete colored
boxes instead of a smooth gradient.
What I'd like to do is make a legend that encompasses all values but also
is a nice set of ticks marked at regular decimal intervals (10 or 100's).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:1&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:2380 cmbarton]:
It disappears when the values are out of the range of the raster map. Look
in console for an error, it might be the case. You can display again a
legend when you click on show/hide (twice, first as hide, second for
show).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:2&gt;
      Cpu: Unspecified |
The values were in range. I tried clicking legend show/hide a couple of
times and nothing happened.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:3&gt;
      Cpu: Unspecified |
Replying to [comment:3 cmbarton]:
Any error?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:4&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:1 cmbarton]:
instead
are the spaces real? there shouldn't be any around the commas.
boxes
That's exactly what the use= option does; it uses those discrete values.
E.g. for a logarithmic scale.
also
100's).
Generally the way to do that is to pick a min,max for range= near a whole
number (I don't think it needs to be exact?) then set the labelnum= option
appropriately to get the ticks on nice clean divisions.
ps.map uses a completely different logic for selecting the tick mark
values; I tend to prefer d.legend's way as it gives the cartographer more
control, but using ps.map may automagically give you what you're looking
for.
regards,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:5&gt;
      Cpu: Unspecified |
Changes (by hamish):
* cc: hamish (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2380#comment:6&gt;
      Cpu: Unspecified |
I thought you might be right about the space, but it turns out that it
makes no difference. The problem is when one of the numbers in the list is
out of range. Interestingly, the error says
"Command 'd.legend rast=shortdomestic_dates@NeolSpread
use=6600,6800,6900 at=5,50,7,10' failed
Details: use=6600 out of range [6689.075, 7299.539] (extend
with range= ?)"
But specifying a wider range with range=? does not work. A work around for
this issue is to use r.colors to define a color table matching the desired
range (i.e., of even, round numbers). Then range=? works for the new range
and use=? does not cause the legend to disappear. It would be nice if
range=? did this without the r.colors workaround. So this part is an
enhancement request now.
The biggest problem from a user standpoint is that when the legend
disappears and you have closed the command dialog (i.e., by pressing "OK",
there is no way to get it back. Selecting "Show/hide legend" in the
toolbar menu will not make the command dialog reappear. You can only fix
it by closing the display and opening a new one. While perhaps not a bug
per se, this is not desirable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2380#comment:7&gt;
      Cpu: Unspecified |
Replying to [comment:7 cmbarton]:
> with range= ?)"
I would say that warning would be more appropriate than fatal error. There
is already a warning about exceeding range which is similar case.
Hm, for me the dialog reappears, at least in the newest GRASS version.
What about any Python error message in the console?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2380#comment:8&gt;
Component: wxGUI | Version: svn-trunk
      Cpu: Unspecified |
  * component: Display => wxGUI
Comment:
I'd expect it to fail with the space, I don't remember a G_squeeze()
anywhere which would remove them. Maybe atof() does that automatically.
I'd recommend to not put them in on purpose.
> The problem is when one of the numbers in the list is out of range.
ok, so the error message is not fed back to the user in an obvious way
when d.legend is launched from the wxGUI display button?
> with range= ?)"
for this
range
> (i.e., of even, round numbers). Then range=? works for the new range and
use=?
Right, the "extend with range=" message implies that, even though it
doesn't
say so. Referring to the man page:
        The range option lets the user define the minimum
        and maximum categories to be used in the legend. It
        may also be used to define the limits of a smooth
        gradient legend created from a raster containing
        floating point values. Note the color scale will
        remain faithful to the category values as defined
        with r.colors, and the range may be extended to the
        limits defined by the r.colors color map.
> It would be nice if range=? did this without the r.colors workaround.
It can't and won't do that. Only r.colors is allowed to (re)set color
tables,
d.legend will not. The alternative is to have [ugly] empty space beyond
the
min and the max of the color table range within the smoothed legend box,
I'd
prefer to not allow that. (the module cannot look up the color values
which
are outside of the raster map's color table, since they don't exist. *The
resulting out-of-bounds color isn't technically undefined, you can set it
with the r.colors "default" rule, but I'd rather treat it as an error in
the case of d.legend.)
Anna:
> There is already a warning about exceeding range which is similar case.
Similar but different. One is recoverable, but may suggest user error. The
other
is not since it can't look up a color value which does not exist. fwiw
I've
considered downgrading the beyond-actual-range warning into a regular
message,
since for a long time-series with common color table (as asked about
recently
on the ML), such as series of temperature maps over a year, that happens
all
the time and can be too noisy when run in a loop.
regards,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2380#comment:9&gt;
