#2384: v.vect.stats not in GUI
Reporter: alanglen89 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.5
Component: Vector | Version: unspecified
Keywords: | Platform: MSWindows 8
Cpu: x86-64 |
The module v.vect.stats is included in version 6.4.5, but is missing or is
hard to find using the GUI. Looking through all the buttons and searching
with the search module gives no results. However, I found using the
Command Console, it is possible to type v.vect.stats to access/run the
module.
Request: Add v.vect.stats to the GUI menu.
Thank you for your continuing to improve GrassGIS!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2384>
