[GRASS-dev] [GRASS GIS] #239: crash if zooming in too much
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
r32363
1. Add a raster map (raster or vector).
2. Zoom in until an error like this pops up:
Execution failed: 'd.rast map=N51E016@PERMANENT --q'
Details:
  ERROR: region for current mapset line 1run "g.region"
3. Try to "Zoom to selected map" or any other zoom operation - a crash:
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 2076, in OnZoomToMap
self.ZoomToMap()
pdisp.py", line 2129, in ZoomToMap
self.UpdateMap()
pdisp.py", line 579, in UpdateMap
self.mapfile = self.Map.Render(force=True,
mapWindow=self.parent, windres=windres)
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/re
nder.py", line 762, in Render
if not layer.Render():
nder.py", line 135, in Render
os.environ["GRASS_PNGFILE"] = self.mapfile
   File "/usr/lib/python2.5/os.py", line 474, in __setitem__
putenv(key, item)
TypeError
putenv() argument 2 must be string, not None
Ticket URL: <http://trac.osgeo.org/grass/ticket/239&gt;
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
  * component: default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/239#comment:1&gt;
Changes (by msieczka):
* cc: cmbarton (added)
Comment:
Michael Barton commented on GRASS dev ML:
Arrgh. Fixed this in TclTk but seems like we need to fix it in wxPython
too. Thanks for spotting it. With new graphic tools in wxpython, Glynn's
rewrite of the display drivers, and Martin's work on nD visualization we
may be reworking the display rendering engine. At the moment, I'm not sure
how much will be back ported to wxpython. We might try a simple patch on
this for the moment, however. I'll try to look into it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/239#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
I just tested this on current 6.4 svn. I zoomed until I got an error
similar to the one above, with the added explanation that the zoomed
region was smaller than the region resolution. In fact it was a LOT
smaller than the region resolution by the time I hit this error.
But the error simply raised an error message and did not cause a crash. I
zoomed to selected map and it worked fine.
I think this has been fixed in the year since this was last reported. If
this causes a crash on someone else's system, we can reopen it.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/239#comment:3&gt;
