[GRASS-dev] [GRASS GIS] #2391: font setting for map display broken on Mac
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
The font setting dialog for map display in preferences does not work on
the Mac. It displays an empty window rather than a list of fonts.
The font setting dialog for command output works fine however. The widget
used for command output fonts should also be used for map display fonts.
This behavior is the same in GRASS 7.0 beta 3 and 7.1.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391&gt;
Keywords: font | Platform: All
      Cpu: OSX/Intel |
Changes (by annakrat):
  * keywords: => font
  * platform: MacOSX => All
Comment:
I fixed it in r61603. The font dialogs are different intentionally, I
would say. The dialog for the commands uses system dialog because the font
is then used in the GUI. The other dialog takes fonts from d.fontlist and
this font is then used for d.commands. I don't understand how d.fontlist
works but maybe that under certain conditions these lists of fonts may be
different?
I will backport after testing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391#comment:1&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
Thanks Anna. The other reason for the difference is that the wxPython font
dialog was broken on the Mac. Maybe it will be fixed by v. 2.9 or 3.0
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by annakrat):
Replying to [comment:2 cmbarton]:
font dialog was broken on the Mac. Maybe it will be fixed by v. 2.9 or 3.0
It doesn't seem to be broken any more.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: font
  Platform: All | Cpu: OSX/Intel
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:1 annakrat]:
Done in r61677.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391#comment:4&gt;
