[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
application
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Component: Startup | Version: svn-releasebranch70
Keywords: cygwin, wingrass, environmetal variables | Platform: MSWindows 8
      Cpu: Unspecified |
Reported on mailing list, I don't know how Cygwin works, so this might be
partially problem on user side but startup should be able to handle this.
On [http://lists.osgeo.org/pipermail/grass-user/2014-August/070726.html
Tue, Aug 19, 2014 at 2:58 AM, Sindile Bidla] wrote:
> /usr/bin/bash.exe: Command not found
The problem is that "/usr/bin/bash.exe" is expected but not found. Why it
is expected? Because once CYGWIN variable is in environmental variables,
GRASS start up script thinks that it runs in the Cygwin mode and for some
reasons needs to use full path.
#!python
     # cygwin has many problems with the shell setup
     # below, so i hardcoded everything here.
     if os.getenv('CYGWIN'):
         sh = "cygwin"
         shellname = "GNU Bash (Cygwin)"
         os.environ['SHELL'] = "/usr/bin/bash.exe"
         os.environ['OSTYPE'] = "cygwin"
In any case, this is not supposed to work as OSGeo4W and standalone GRASS
are not Cygwin applications. They are native MS Windows applications, so
this would anyway fail later.
The problem is that you have CYGWIN variable in you environment and GRASS
GIS then thinks that it is supposed to run as Cygwin application. This
leads to three questions.
1) Do you need CYGWIN variable in you environment for some reason? Are you
using some Cygwin applications? (I don't know if the later implies the
former but it seems that the Cygwin environment is not correct anyway.)
Removing CYGWIN from the environment (at least for GRASS if this is
possible on MS Windows) would workaround GRASS imperfect deciding about
type of application it is (Cygwin or MS Windows native).
2) For GRASS GIS, is there some better way of getting to know if it is
running as Cygwin application?
3) Is this Cygwin part even needed? We are not relying on Cygwin in GRASS
GIS 7 anymore and we don't plan to do so, as far as I know. So, a possile
solution is just removing this Cygwin-related code.
Note that this is quite high priority because GRASS will not start when
CYGWIN is in the enviroment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395&gt;
application
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2395 wenzeslaus]:
FWIW, the CYGWIN variable isn't even set in my Cygwin64 environment, so
checking it may lead to false negatives as well as false positives.
For a Python script, sys.platform will tell you if you're running a Cygwin
version of Python.
Another option would be to check for the presence of the variable SHELL in
the environment. If it doesn't exist, GRASS is probably being launched
from a desktop icon or start menu entry, in which case the GUI should be
started directly. If SHELL is set, GRASS should spawn a session using that
shell, in the current console.
Ideally, we shouldn't be trying to distinguish Cygwin from other Unix
platforms except where this turns out to be strictly necessary.
GRASS GIS 7 anymore and we don't plan to do so, as far as I know. So, a
possile solution is just removing this Cygwin-related code.
This isn't version-specific. For a long time, we have offered GRASS for
both (native) Windows and Cygwin. Some Windows users (e.g. those who
already use Cygwin for other reasons) may prefer the Cygwin version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:1&gt;
application
      Cpu: Unspecified |
Comment(by sindile):
I have replaced etc\grass70.py with the attached grass.py (have renamed it
to grass70.py) as per this email http://lists.osgeo.org/pipermail/grass-
user/2014-August/070728.html
This is the error I get,
firstly I get a libgrass_gis.7.0.0beta3.dll missing error and then the
following
Cleaning up temporary files...
Starting GRASS GIS...
Unable to import pyGRASS: grass_gis.7.0.0beta3 not found.
Some functionality will be not accessible
           __________ ___ __________ _______________
          / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
         / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
        \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS @GRASS_VERSION_NUMBER@
GRASS homepage: http://grass.osgeo.org
This version running through: Bourne Shell
(C:\OSGeo4W\apps\msys\bin\
sh.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
GRASS @GRASS_VERSION_NUMBER@> Unable to import pyGRASS:
  found.
   File "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\wxgui.py",
line 34,
in <module>
     from lmgr.frame import GMFrame
   File
"C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\lmgr\frame.py", line
  50, in <module>
     from lmgr.layertree import LayerTree, LMIcons
   File
"C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\lmgr\layertree.py",
line 37, in <module>
     from mapdisp.frame import MapFrame
   File
"C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\mapdisp\frame.py", l
ine 35, in <module>
     from vdigit.toolbars import VDigitToolbar
   File
"C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\vdigit\toolbars.py",
  line 30, in <module>
     from iclass.digit import IClassVDigit
   File
"C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\iclass\digit.py", li
ne 23, in <module>
     from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Furthermore I do not have a CYGWIN in my environmental variables defined.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:2&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 sindile]:
it to grass70.py) as per this email http://lists.osgeo.org/pipermail
/grass-user/2014-August/070728.html
  in the attached script
# Variables substituted during build process
if 'GISBASE' in os.environ:
     gisbase = os.environ['GISBASE']
else:
     gisbase = "@GISBASE@"
cmd_name = "@START_UP@"
grass_version = "@GRASS_VERSION_NUMBER@"
ld_library_path_var = '@LD_LIBRARY_PATH_VAR@'
if 'GRASS_PROJSHARE' in os.environ:
     config_projshare = os.environ['GRASS_PROJSHARE']
else:
     config_projshare = "@CONFIG_PROJSHARE@"
it should be something (adapted to beta3) like
else:
     gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.0svn"
cmd_name = "grass70"
grass_version = "7.0.0svn"
ld_library_path_var = 'PATH'
else:
     config_projshare = "/c/OSGeo4W/share/proj"
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:3&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:3 hellik]:
renamed it to grass70.py) as per this email
http://lists.osgeo.org/pipermail/grass-user/2014-August/070728.html
> else:
> else:
> else:
> else:
for beta3 in osgeo4w it should be:
else:
     gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.0beta3"
grass_version = "7.0.0beta3"
else:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:4&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
defined.
instead of the CYGWIN issue, could it be some kind of an incomplete
installation caused by missing admin rights (right click and install as
admin - standalone as well osgeo4w) or by some blocking antivirus
software?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:5&gt;
application
      Cpu: Unspecified |
Comment(by zarch):
[cut]
a cleaned version could be:
gisbase = os.environ.get('GISBASE',
"/c/OSGeo4W/apps/grass/grass-7.0.0svn")
config_projshare = os.environ.get('GRASS_PROJSHARE',
"/c/OSGeo4W/share/proj")
And I believe that variables: cmd_name and grass_version that at the
moment are hard-coded should be defined in some more clever way.
I'm not sure but I think that even the path: /c/OSGeo4W/ could/should be a
variable in case that the user change the default installation directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:6&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:6 zarch]:
a variable in case that the user change the default installation
directory.
the path (is?)/should be adapted by the osgeo4w-installation-script.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:7&gt;
application
      Cpu: Unspecified |
software?
I have installed by right click and install as admin on osgeo4w as well as
the standalone and Grass 7.0.0 beta3 works. I also did not have to replace
/etc/grass70.py
This is strange because with previous version I never needed to right
click and install as admin.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:8&gt;
application
      Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:1 glynn]:
Cygwin version of Python.
So, I will change this accoring to [http://lists.osgeo.org/pipermail
/grass-user/2014-August/070728.html GRASS-user Grass-7.0 beta3 fails to
launch]:
if sys.platform == 'cygwin':
I'm just not sure from the documentation if "equals", "startswith", or
"in" is more appropriate.
in the environment. If it doesn't exist, GRASS is probably being launched
According to comment and the source code I think that `SHELL` variable
might be somehow wrong sometimes.
  * source:grass/trunk/lib/init/grass.py#L906
Yes, we would be defeating the purpose of Unix and Cygwin then but I guess
this is the exception.
OK, if we still support Cygwin and it is still possible to install GRASS
GIS like this we need to keep the code there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:9&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:8 sindile]:
software?
as the standalone and Grass 7.0.0 beta3 works. I also did not have to
replace /etc/grass70.py
installing as admin is default since a few years now (standalone ~3 years,
osgeo4w ~1 year).
any change on your system?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:10&gt;
application
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:9 wenzeslaus]:
so checking it may lead to false negatives as well as false positives.
is running as Cygwin application?
launch]:
SHELL in the environment. If it doesn't exist, GRASS is probably being
launched from a desktop icon or start menu entry, in which case the GUI
should be started directly. If SHELL is set, GRASS should spawn a session
using that shell, in the current console.
guess this is the exception.
for both (native) Windows and Cygwin. Some Windows users (e.g. those who
as the source of original failure report is an incomplete installation,
closing ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:11&gt;
application
      Type: defect | Status: closed
Resolution: fixed | Keywords: cygwin, wingrass, environmetal variables
  Platform: MSWindows 8 | Cpu: Unspecified
Changes (by wenzeslaus):
  * status: new => closed
  * resolution: => fixed
Comment:
launch].
Committed to trunk and 70 in r61705 and r61706.
Replying to [comment:11 hellik]:
closing ticket?
Closing. However, shouldn't the installer tell you that it was in fact
unsuccessful installation and that nothing will work, or that you are not
running it with admin rights (assuming now that admin right are really
necessary). I guess that GRASS itself cannot tell much since it is broken.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:12&gt;
application
Comment(by hellik):
Replying to [comment:12 wenzeslaus]:
launch].
installation, closing ticket?
few years ago I've implemented in the standalone installer to ask/install
by admin
http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
Installer.nsi.tmpl#L100
100 ;Request application privileges for Windows
101 RequestExecutionLevel admin
by simple double clicking (no right click) on the standalone installer,
you ''should'' be asked to grant admin rights. similar is implemented in
the OSGeo4W-setup.
regarding ''should'', as there are so many different flavours of windows
with too many different system rights settings out there in the wild, it's
hardly possible to catch all possible hurdles.
at least it should be mentioned in the download page.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:13&gt;
application
Comment(by hellik):
Replying to [comment:13 hellik]:
the OSGeo4W-setup.
additional check may be if you run as admin:
[http://stackoverflow.com/questions/8732019/how-do-you-request-
administrator-permissions-using-nsis example 1]
[http://stackoverflow.com/questions/8821476/nsis-installing-an-
application-to-always-run-as-administrator example 2]
something like:
!include LogicLib.nsh
Function .onInit
UserInfo::GetAccountType
pop $0
${If} $0 != "admin" ;Require admin rights on NT4+
     MessageBox mb_iconstop "Administrator rights required!"
     SetErrorLevel 740 ;ERROR_ELEVATION_REQUIRED
     Quit
${EndIf}
FunctionEnd
Page InstFile
Section
SectionEnd
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:14&gt;
application
following
Are you sure that you are not getting the error dialogs with missing
MS...DLL files? I have just seen similar/same errors on some MS Windows 7
computer.
The [http://grass.osgeo.org/download/software/ms-windows/ GRASS download
page for MS Windows] says:
> Troubleshooting: If the program exits immediately after you start it or
it complains about a missing MSVCR71.dll, MSCVP100.dll or similar on
startup, you may need to install Microsoft's .NET Framework. See also
WinGRASS errors (and their solution).
But .NET Framework was not enough and we had to go to
[http://grasswiki.osgeo.org/wiki/WinGRASS_errors linked wiki page] and use
the last option "mimic what installer is doing".
It is actually the second computer I see where was necessary to do the
"mimic what installer is doing" steps. I don't have an idea what does this
mean.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:15&gt;
