#2398: grass.exec_command should add .exe where needed
Reporter: michikommader | Owner: grass-dev@…
Type: defect | Status: new
Component: Python | Version: svn-releasebranch70
Keywords: | Platform: MSWindows 7
Cpu: x86-32 |
Using the GUI or CMD-interface I get the following error when running
v.centroids:
v.centroids input=in output=out
File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\scripts\v.centr
oids.py", line 69, in <module>
main()
oids.py", line 63, in main
grass.exec_command("v.category", type = 'area',
**options)
File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\etc\python\gras
s\script\core.py", line 499, in exec_command
os.execvpe(prog, args, env)
Peeking into scripts/v.centroids.py at line 63 reveals a call to
grass.exec_command("v.category", type = 'area', **options)
which fixes the error when changed to
grass.exec_command("v.category.exe", type = 'area', **options)
It looks like you have to add a ".exe" in some cases under Windows.
Cpu: x86-32 |
Comment(by glynn):
Replying to [ticket:2398 michikommader]:
It isn't quite that simple, as it's perfectly valid to "exec" a script.
Unlike the other *_command() functions, exec_command() isn't based upon
Popen() objects, but upon os.execvpe().
os.execvpe() will attempt to locate the executable in the directories
specified by PATH, but it won't attempt to determine the suffix according
to PATHEXT. The only way in which we could determine the suffix is to
enumerate over both PATH and PATHEXT until a match is found.
Alternatively, we could just "fake it" on Windows by calling e.g.
run_command() then exit()ing as soon as it returns. I'm fairly sure that's
what the Windows' execvpe() is doing (on Unix, the exec* functions replace
the program for the current process).
