#2399: *.colors.out: simplified colors output
Reporter: lucadelu | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: colors, r.colors.out, v.colors.out | Platform: All
Cpu: Unspecified |
Hi devs,
At time the *.colors.out commands output a color table as-is. This
is not necessarily useful when it comes to export for WMS etc which
ideally uses a minimalistic color table.
Example: a Celsius temperature map comes with a long FP color table
but for Web representation it is sufficient to provide a simplified
table.
Hence, the *.colors.out could offer a reclassified table based on
the original FP color table.
Proposal:
To optionally reduce the number of output colors values for a
map, I introduced a new parameter (classes) in *.colors.out.
It works as follows:
* first obtain the number of all color values and divide it with the
number of classes set by the user to obtain the bin size,
* In the existing Rast_print_colors() there is a "for" loop in which we
can check the values if the color table row is the first, last or a
multiple of our bin size and restrict printing to only these values.
At this point, *.colors.out will no longer only print the original FP
color table, but optionally also a reduced classified color table for
external use.
Please try the attached patch (one parameter added to Rast_print_colors()
and update of respective calls elsewhere in GRASS) and let me know if
acceptable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2399>
