[GRASS-dev] [GRASS GIS] #240: import all files within a directory
Reporter: timmie | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
This was discussed for shapefile vectors at:
http://news.gmane.org/gmane.comp.gis.grass.user
>> * I cannot just point the program to a directory of shapefiles and tell
>> it import all. QGIS, gvSIG and ArcGIS can do this.
> We could easily add v.in.ogr.all or v.external.all, I suppose two or
> three lines of shell script :slight_smile: Could be stored in the Addons wiki.
This chould be enabled for vector and raster files.
Examples:
- Import all landcover vector files from a folder
- Import all SRTM ASC/TIFF files from a folder
a nice option would be if one could run ogr2ogr/v.patch or
gdal_merge/r.patch while importing to generate a mosaik of all the tiles
within the folder with the same step.
This should also be implemented for the GUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/240&gt;
  Priority: major | Milestone: 7.0.0
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by neteler):
  * platform: Unspecified => All
  * type: defect => enhancement
  * cpu: Unspecified => All
  * milestone: 6.4.0 => 7.0.0
Comment:
An option may be to implement wildcard support in r.in.gdal|v.in.ogr.
Possibly a GDAL/OGR function could be called to merge before handing
the data block over to GRASS (within the modules).
Ticket URL: <http://trac.osgeo.org/grass/ticket/240#comment:1&gt;
Comment (by glynn):
Replying to [comment:1 neteler]:
It doesn't make any sense to implement this within the module.
If you are going to run the entire top-level of a module in a loop, you're
better off just running the module itself in a loop.
Ticket URL: <http://trac.osgeo.org/grass/ticket/240#comment:2&gt;
