[GRASS-dev] [GRASS GIS] #2402: v.distance in Long/Lat Locations on GRASS 7.0
Reporter: micha | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: | Platform: All
      Cpu: Unspecified |
In stable version 6.4, when working in a Long-Lat LOCATION, v.distance
returns geodesic distance on a sphere in meters (in the cases of point to
point, and point to line).
In GRASS 7.0 this feature is lost, and distances are always returned in
the LOCATION units (i.e. degrees in a Long-Lat LOCATION). Geodesic
distance should be the preferred behavior.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2402&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
This would be a blocker for 7.0 release unless the current (7.0's)
behavior will be a default and requested requested behavior optional.
See also #2401 for 6.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2402#comment:1&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 wenzeslaus]:
I think that geodesic distances in LL-locations should stay the default
behaviour, but even if we decide to make it optional, it still needs to be
implemented [1].
Markus M: as you implemented the new version of v.distance, can you tell
us quickly what needs to be done ?
Moritz
[1]
[https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.distance/distance.c#L6]
Ticket URL: <http://trac.osgeo.org/grass/ticket/2402#comment:2&gt;
      Cpu: Unspecified |
In the attached patch, I had a quick go at it, in line with the patch for
grass6.
Needs testing, though.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2402#comment:3&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:2402 micha]:
Fixed for trunk in r61850.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2402#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 mmetz]:
in the LOCATION units (i.e. degrees in a Long-Lat LOCATION). Geodesic
With the NC-data reprojected to EPSG 4326, I get the following now:
v.distance -p from=comm_colleges to=comm_colleges upload=dist col=dist
dmin=0.0001
Finding nearest features...
  100%
  100%
from_cat|dist
1|null
2|null
3|null
55|null
56|null
57|null
58|null
  100%
58 categories - no nearest feature found
Whereas the same command in the NC-location gives me the expected list of
distances.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2402#comment:5&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:5 mlennert]:
v.distance returns geodesic distance on a sphere in meters (in the cases
of point to point, and point to line).
dmin=0.0001
  100%
  100%
from_cat|dist
1|null
2|null
3|null
55|null
56|null
57|null
58|null
  100%
Oops. Fixed in r61861.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2402#comment:6&gt;
      Cpu: Unspecified |
Replying to [comment:6 mmetz]:
returned in the LOCATION units (i.e. degrees in a Long-Lat LOCATION).
Geodesic distance should be the preferred behavior.
dmin=0.0001
> 100%
> 100%
> from_cat|dist
> 1|null
> 2|null
> 3|null
> 55|null
> 56|null
> 57|null
> 58|null
> 100%
I just found a difference in distances calculated with grass6 and grass7
for points to areas (see explanation in #2401). Needs checking.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2402#comment:7&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:7 mlennert]:
G6 and G7 produced nearly identical results after the last change to
v.distance in trunk, but now (r61978) there is
Vect_line_geodesic_distance() available in trunk and v.distance makes use
of it (r61979). The results in latlong are now more similar to the results
in the original NC projection. In particular, the larger deviations
present in G6 have now disappeared in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2402#comment:8&gt;
