[GRASS-dev] [GRASS GIS] #2403: cairo driver fails to create surface
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: cairo, resolution, surface | Platform: Linux
      Cpu: x86-64 |
Steps to reproduce:
g.region rast=elevation res=0.1 -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 0.1
ewres: 0.1
rows: 135000
cols: 150000
cells: 20250000000
Rendering via Cairo driver fails:
d.mon cairo
d.rast elevation
ERROR: Cairo_begin_raster(): Failed to create surface (invalid value
(typically too big) for the size of the input (surface, pattern, etc.)).
Using rows: 135000, cols: 150000
While PNG driver works:
d.mon -r
d.mon png
d.rast elevation
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
wxGUI also works since it uses it's own display resolution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403&gt;
Reporter: martinl | Owner: martinl
     Type: defect | Status: assigned
      Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:1&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:2403 martinl]:
It would be possible to change the cairo driver (lib/cairodriver/Raster.c)
to render each row separately.
However, this would effectively preclude adding certain features (e.g.
anti-aliasing or rotation). It would also make a mess of the file
structure for formats such as SVG.
For those reasons, I'd suggest making row-by-row rendering an alternative
to the existing method rather than simply replacing it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:2&gt;
      Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:2 glynn]:
(lib/cairodriver/Raster.c) to render each row separately.
for record https://bugs.freedesktop.org/show_bug.cgi?id=85561
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:3&gt;
      Cpu: x86-64 |
Replying to [comment:3 martinl]:
the problem is that cairo limits number of rows and cols to 32767 (1). Any
idea how this bug could be resolved in GRASS?
(1) http://cgit.freedesktop.org/cairo/tree/src/cairo-image-surface.c#n61
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:4&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:4 martinl]:
Any idea how this bug could be resolved in GRASS?
One option is to require clients (d.rast, d.his, d.rgb) to limit the
region resolution. Another is to modify the driver(s) to decimate the data
if it exceeds certain limits. Yet another is to modify the cairo driver to
down-sample the data itself (this avoids the issue that a source region of
32767x32767 will require 4 GiB of memory to store the surface regardless
of the output resolution).
All of these have the advantage that the client won't waste time reading
rows which will be discarded by the driver (when down-sampling, the driver
reports the next row which will be used).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:5&gt;
      Cpu: x86-64 |
Replying to [comment:5 glynn]:
> another is to modify the cairo driver to down-sample the data itself
(this avoids the issue that a source region of 32767x32767 will require 4
GiB of memory to store the surface regardless of the output resolution).
I was thinking about something similar, btw, is there any display driver
in GRASS which already doing down-sampling? Thanks for any hint.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:6&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:6 martinl]:
The PNG driver resamples each row and stores it directly in the image.
The PS driver writes the data to the PostScript file as-is (after
conversion to hex). This can potentially result in huge files, but it
doesn't affect memory requirements (PostScript "streams" image data into
the frame-buffer from the input file; it doesn't store it in memory prior
to rendering).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:7&gt;
      Cpu: x86-64 |
Replying to [comment:7 glynn]:
Thanks for the hint. Could you please review
attachment:cairo_down_sampling.diff which do down-sampling for Cairo in
similar as already does PNG driver?
Down-sampling has of course a significant speed effect when rendering
larger rasters using their original region, eg.
g.region rast=dmt -p
rows: 11682
cols: 18913
cells: 220941666
# cairo: no down-sampling
time GRASS_RENDER_IMMEDIATE=cairo d.rast dmt
real 0m40.797s
# cairo: down-sampling (patch applied)
real 0m1.400s
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:8&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:8 martinl]:
> Could you please review attachment:cairo_down_sampling.diff which do
down-sampling for Cairo in similar as already does PNG driver?
The main issue was that it neglected the inner Y loop when up-scaling.
r63582 makes the cairo driver behave almost identically to the PNG driver.
For reasons which I've been unable to determine so far, the result is one
destination pixel wider than with the PNG driver.
Ultimately, the code should be modified to use an intermediate surface
which has the same dimensions as the destination rectangle, to avoid the
overhead of copying the (empty) borders.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: cairo, resolution, surface
  Platform: Linux | Cpu: x86-64
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:9 glynn]:
driver.
I took liberty to backport it in r63595.
one destination pixel wider than with the PNG driver.
Since the originally reported issue has been fixed, I took liberty to
close this ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:10&gt;
Comment(by neteler):
This is excellent! Thanks, Glynn.
This (formerly failing) example was done over NFS mounted /grassdata over
a 1Gb/s intranet connection with local GRASS GIS installation and remote
network data repository:
GRASS 7.0.0svn (eu_laea):~ > g.region rast=lst_2014_03_minimum -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: etrs89
ellipsoid: grs80
north: 5447750
south: 770000
west: 2168000
east: 7716750
nsres: 250
ewres: 250
rows: 18711
cols: 22195
cells: 415290645
GRASS 7.0.0svn (eu_laea):~ > d.mon wx0
GRASS 7.0.0svn (eu_laea):~ > time -p d.rast lst_2014_03_minimum
  100%
real 34.12
user 33.13
sys 0.67
##### comparison to see how long data reading itself takes:
GRASS 7.0.0svn (eu_laea):~ > time -p r.stats lst_2014_03_minimum
real 12.45
user 12.26
sys 0.12
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:11&gt;
Comment(by glynn):
Replying to [comment:11 neteler]:
FWIW, the comparison isn't particularly meaningful, as d.rast now only
needs to read the rows which are actually rendered, while r.stats needs to
read the entire map.
Beyond the need to uncompress entire rows, the rendering time should be
dictated by the output width, not the input width. However, d.rast's
values= feature adds overhead proportional to the input width.
Can you try commenting out the mask_raster_array() call at line 71 of
display/d.rast/display.c? If that has a significant impact, we should try
to skip that call altogether when values= isn't being used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:12&gt;
Replying to [comment:12 glynn]:
Sure. Test setting: connected from home via ssh/tsocks tunnel over ADSL
connection. Opening GRASS 7.0.svn (r63585) remotely, tunnelling wx0 over
network:
rows: 18711
cols: 22195
cells: 415290645
# original
d.mon wx0
time -p d.rast europe_altitude_map.shade
  100%
real 4.64
user 0.93
sys 0.03
# with commented line of mask_raster_array() call
d.mon wx0 # ... previously opened monitor closed
  100%
real 0.92
user 0.91
sys 0.01
Probably that's significant.
Note: This is the time when d.rast finishes and returns to the command
line. The display in d.mon wx0 comes many seconds later but that's of
course a different issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:13&gt;
driver.
Not sure if related but here I remember ticket #72.
Should the ticket be reopened for this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:14&gt;
Replying to [comment:14 neteler]:
If so, please open a new ticket. It's hard to follow tickets with multiple
issues...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:15&gt;
