#2405: WXGUI-3D view, workspace not saving all the position changes made
Reporter: spareeth | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-releasebranch70
Keywords: wxNVIZ | Platform: Linux
Cpu: Unspecified |
Hi
I am preparing a 3D workspace to use it as input to the g.gui.animation
tool.
When I make changes in the map display, the changes are not reflected in
the layer manager > 3D view > view tab and in the saved workspace file.
But when I make changes in the layer manager > 3D view > view tab, the
workspace is saved appropriately with the changed parameters.
It is much easier to set the 3d map position in map display, so nice to
get this issue corrected
Cpu: Unspecified |
Comment(by annakrat):
I am not sure if I understand correctly the problem. When switching from
2D to 3D, the displayed region is always taken from the current 2D extent.
For g.gui.animation, save the workspace when you are in 3D mode. Could you
please try to explain it again?
Cpu: Unspecified |
Comment(by neteler):
I checked as well (NagsHead dataset): The issue happens with the
convenient
"Rotate 3D Scene" button, any change there is not stored in the workspace
file, but
it stores the display view values from the standard positioning tool.
For the affected few lines in the workspace file, see attached
"nagshead_gxw.diff".
