#2407: Rename i.tasscap to i.landsat.tasscap?
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Imagery | Version: svn-releasebranch70
Keywords: i.tasscap, landsat | Platform: All
Cpu: All |
Hi GRASS devs,
the module description for i.tasscap states "Performs Tasseled Cap (Kauth
Thomas) transformation for LANDSAT-TM data".
If the module only works for LANDSAT data, I'd suggest to rename it to
i.landsat.tasscap. If the module also works for other satellite imagery
the module description should be broadened a little bit.
Sorry, I'm not a remote sensing expert myself.
As suggested by Martin L. last week I marked it as blocker.
Cpu: All |
Comment(by neteler):
Good point but in my view it would be better to add more sensors,
e.g. Quickbird, CBERS etc. In case we get those other tasseled cap
coefficients
(I see that some have been published online) we could add a sensor=xxx
parameter.
Replying to [comment:1 neteler]:
coefficients
> parameter.
Replying to [comment:3 martinl]:
coefficients
> > parameter.
> So close the ticket as `wontfix`?
Absolutely fine by me. I've no strong feelings about leaving it as is (as
I even cannot help to improve it to include new sensors).
Side note: I'm not sure if a new (even blocking?) ticket is required,
asking for these new parameters like 'sensor' to be foreseen in the future
- I'm just wondering because of the upcoming RC. I'm also guessing that a
number of other parameters could change as well. Certainly not my decision
to make
Replying to [comment:4 jbrauner]:
to make
I'm not following this issue but in general blocker is required only if
the API is changed in backwards incompatible manner. So, if you are adding
parameter but it has a default which gives the equivalent result as the
previous version it is OK.
Replying to [comment:5 wenzeslaus]:
to make
Replying to [comment:7 neteler]:
if the API is changed in backwards incompatible manner.
> Yes: In this case the actual flags need to be turned into values for the
new sensor= parameter.
> (see http://grass.osgeo.org/grass70/manuals/i.tasscap.html):
> sensor=landsat4,landsat5,landsat7,landsat8,quickbird,...
The new version committed in r61920 to trunk has `satellite` option
instead of flags and one `input` option instead of several `band*`
options.
Several naming changes done with MarkusN in order to be more precise about
satellite/sensor. Feedback welcome, especially the manual page should be
reviewed. I tested that but more testing would be helpful too.
Now it is possible to add new satellites/sensors easily without breaking
API.
This ticket can be closed once the change is backported to 7.0.
Replying to [comment:8 wenzeslaus]:
the new sensor= parameter.
options.
about satellite/sensor. Feedback welcome, especially the manual page
should be reviewed. I tested that but more testing would be helpful too.
Seems to work as expected (however I cannot check whether the calculations
are semantically correct), manual seems fine as well. Great job! Once
again I'm fairly impressed by you devs.
API.
