#2409: last call for options keys consolidation
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:158 hellik]:
> stream_rast Name for output raster map with unique stream ids
changed to `stream_raster` in r63706
> stream_vect Name for output vector map with unique stream ids
changed to `stream_vector` in r63706
> transmissivity_singleway Name of single-way transmissivity raster
map [0.0-1.0]
> transmissivitysingleway Name of the single-way atmospheric
transmissivitymap [-]
`transmissivitysingleway` changed to `transmissivity_singleway` in r63709
> walk_coeff Coefficients for walking energy formula parameters a,b,c,d
> transport_coeff Name of transport capacity coefficient raster map
[s]
> topidxclass Topographic index class
> topidxstats Name of topographic index statistics file
> tiledimension The dimensions of the tiles used in the output raster3d
map (XxYxZ or default: 16x16x8)
> tilesize The maximum tile size in kilo bytes. Default is 32KB.
> swatershed Name for output sink-watershed raster map
no opinion here
> start_rast Name of starting raster points map
changed to `start_raster` in r63711
> stab Set the flow stabilizing scheme (full or exponential upwinding).
> staend The user defined values that indicate start, intermediate
and end status in the indicator output space time raster dataset
> sourceproj Source projection
> sourcescale Conversion factor from units to meters in source
projection
> soilheatflux Name of instantaneous soil heat flux raster map [W/m2]
> Name of soil heat flux raster map [W/m2]
> soilmoisture Name for output root zone soil moisture raster map
no opinion here
> slope_tol Slope tolerance that defines a 'flat' surface (degrees)
changed to `slope_tolerance` in r63713
> segmax Maximum length of segment on network
> Maximum number of points in a segment
> savehistory Text file in which to save history
> savesettings Name for output file where to save current settings
> rgbmaps Three (R,G,B) 3D raster maps to create RGB values
[redmap,greenmap,bluemap]
> Three (r,g,b) raster maps to create RGB values
> productname Name of MODIS product type
> pclay Name of soil clay fraction raster map [0.0-1.0]
> pcurvature Name for output profile curvature map (or fxx)
> Name for output profile curvature raster map
> outtopidxstats Name for output topographic index statistics file
no opinion here
> nwalkers Number of walkers
> Number of walkers, default is twice the number of
cells
> num_partitions Read the input files in this number of chunks
> npartitions Number of partitions
`num_partitions` changed to `npartitions` (to follow other similar options
like `nwalkers`, `npoints` and others - number of ...)
> ncolumn Node cost column
> Node cost column (number)
This is more significant issue, all of v.net modules uses various
shortened options
> min_area Minimum size of area to be imported (square units)
> min_size Minimum number of pixels in a class
> min_slope Minimum slope value (in percent) for which aspect is
computed
> mcurvature Name for output mean curvature 3D raster map
> Name for output mean curvature map (or fxy)
> Name for output mean curvature raster map
> loadhistory Text file from which to load history
> loadsettings Name of input file to read settings from
> localutctime Name of time of satellite overpass raster map [local time
in UTC]
> insol_time Output insolation time raster map [h] (mode 2 only)
> infil Name of runoff infiltration rate raster map [mm/hr]
> infil_value Runoff infiltration rate unique value [mm/hr]
> infile Input file with one input raster map name and data point
position per line, field separator between name and sample point is |
> init_time Initial time for current simulation (0) (min)
> gcurvature Name for output Gaussian curvature 3D raster map
> beam_rad Output beam irradiance [W.m-2] (mode 1) or irradiation
raster map [Wh.m-2.day-1] (mode 2)
no opinion here
> afcolumn Arc forward/both direction(s) cost column (number)
> acolumn Arcs' cost column (for both directions)
> abcolumn Arc backward direction cost column (number)
> EXPERIMENTAL: Arc backward direction cost column
(number)
see my note about `v.net` modules above
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:163>
