[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
Reporter: martinl | Owner: grass-dev@…
     Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:116 wenzeslaus]:
> [comment:111 annakrat] and [comment:113 hcho] don't want the underscore
for 3D raster, so this changes "`raster` and (`raster_3d` and `raster3d`)"
just to "`raster` and `raster3d`". [comment:102 I] already said that I
prefer `raster3d` over `raster_3d`. In my opinion such a common option
name as one for 3D raster (common for me and name of one of the basic
types) should not have an underscore.
Can someone, anyone, explain what exactly is the problem with underscores?
Why are they bad, why shouldn't we use them, etc?
To my mind, any name that is made of more than one word should have some
kind of separator between the words. For GRASS option names, "some kind of
separator" equates to an underscore.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:121&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:117 mlennert]:
> More generally, this whole issue shows to me what happens in an
unorganised release process where we start to release betas without being
sure that we are in a stable enough state to do so and then begin such a
fundamental review such as this one very late into the process...
It's always the same. If something can be left until later, it is. Once we
reach the "last chance to comment" stage, all of the discussions which
should have happened over the last half-dozen years start.
This isn't specific to GRASS. The standard that eventually became C++11
spent most of its life being referred to as "C++0x" on the assumption that
it would be published by the end of 2009 at the latest.
It's something of a chicken-and-egg problem. You don't get adequate
feedback until many people start using it, and many people won't start
using it until it's perceived as stable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:122&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:121 glynn]:
underscores? Why are they bad, why shouldn't we use them, etc?
To be it looks ok to change the element name "rast3d" to "raster_3d". If I
am not wrong it solves all technical problems, too, including
abbreviations etc.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:123&gt;
      Cpu: Unspecified |
Replying to [comment:123 neteler]:
I am not wrong it solves all technical problems, too, including
abbreviations etc.
Opinions? Let's come to a decision, thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:124&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:124 neteler]:
If I am not wrong it solves all technical problems, too, including
abbreviations etc.
I think most devs are OK with the underscore version. Personally, I don't
like the underscore, but I don't have any powerful argument, so I will
accept it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:125&gt;
      Cpu: Unspecified |
Comment(by hcho):
Replying to [comment:125 annakrat]:
"raster_3d". If I am not wrong it solves all technical problems, too,
including abbreviations etc.
don't like the underscore, but I don't have any powerful argument, so I
will accept it.
Agree. I don't like the underscore version, but I'm OK with raster_3d
because it's at least better than 3draster or 3d_raster. Also, we don't
have to rename any modules and the parser doesn't have to treat numbers as
a special character.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:126&gt;
      Cpu: Unspecified |
Comment(by mlennert):
+1 for raster_3d.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:127&gt;
      Cpu: Unspecified |
Comment(by lucadelu):
Replying to [comment:127 mlennert]:
> +1 for raster_3d.
+1 also for me
> Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:128&gt;
      Cpu: Unspecified |
Comment(by martinl):
> +1 for raster_3d.
+1
I think that it would be useful to modify parser to understand also `rast`
(`rast3d is OK because '_' is treated as word separator).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:129&gt;
      Cpu: Unspecified |
Replying to [comment:129 martinl]:
`rast` (`rast3d is OK because '_' is treated as word separator).
attachment:raster_3d.diff
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:130&gt;
      Cpu: Unspecified |
Comment(by hcho):
Replying to [comment:130 martinl]:
I'm generally against adding special cases in the code. IMHO, if the user
types `rast`, s/he means `raster` not `raster_3d` and it shouldn't be
ambiguous. Currently, the parser would stop with a parameter ambiguous
error. I think it would be more useful to modify the parser such that it
takes the shortest unambiguous parameter with no further underscores.
For example,
* modules with parameters `raster_map=` and `raster_3d=`: `rast` and
`raster_` would be ambiguous.
* modules with parameters `raster=` and `raster_3d=`: `r` and `rast` would
match with `raster=` and `r3` and `rast3` with `raster_3d=`
* modules with parameters `raster_map=` and `raster_map_2=`: `rast`
ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map_2=`
* modules with parameters `raster_map=` and `raster_map2=`: `rast`
ambiguous, `rmap` for `raster_map=` and `rmap2` for `raster_map2=`
I'm not sure if I was clear enough here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:131&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
> +1 for raster_3d.
> Moritz
+1 for me
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:132&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:131 hcho]:
You're suggesting that the abbreviation must include some part of the last
word of the option name? Or that it must include the last character? I.e.
is rm= ambiguous?
The main problems I foresee with that are
  * The last word (or an abbreviation of it) might match some earlier
portion of the option name, meaning that the user intended to specify
(part of) the last word but the characters were matched against an earlier
portion.
  * It's possible for a string to match the last word of multiple options.
E.g. given options raster_map and raster_2_map, rmap would match both
equally.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:133&gt;
      Cpu: Unspecified |
Replying to [comment:132 cmbarton]:
> > +1 for raster_3d.
> > Moritz
> +1 for me
`raster_3d` introduced in r63584.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:134&gt;
      Cpu: Unspecified |
Replying to [comment:134 martinl]:
If no objections I will backport modified element names including
`raster_3d` to relbr70.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:135&gt;
      Cpu: Unspecified |
Comment(by hcho):
Replying to [comment:133 glynn]:
last word of the option name? Or that it must include the last character?
I.e. is rm= ambiguous?
No, not the last word of the option name. You cannot skip any words
separated by an underscore. rm= is not ambiguous in this case because the
shortest option name that matches rm= is raster_map=. If one wants
raster_map2=, use rmap2=, not rm2= (no abbreviation inside a word).
portion.
I'm not talking about skipping words and using the last word, so this is
not the case.
options. E.g. given options raster_map and raster_2_map, rmap would match
both equally.
rmap= would match raster_map= "only" because you cannot skip 2.
Hope I'm clearer now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:136&gt;
      Cpu: Unspecified |
Comment(by hcho):
Replying to [comment:136 hcho]:
I mean the shortest option name with no more following underscores. 'r'
for raster, 'm' for map, and no more underscores after 'raster_map'.
If you have `raster_map_1=` and `raster_map_2=`, `rm=` would be ambiguous
because `raster_map` is still ambiguous. If you have `raster_map=` and
`raster_map_2=`, `rm=` expands to `raster_map=` and it's not ambiguous.
portion.
not the case.
both equally.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:137&gt;
      Cpu: Unspecified |
Replying to [comment:135 martinl]:
done in r63617.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:138&gt;
      Cpu: Unspecified |
More element name change related updates in r63619 and r63620 (shell
scripts)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:139&gt;
      Cpu: Unspecified |
Comment(by hcho):
BTW, we don't rename `oldvector` and `asciivector` to `old_vector` and
`ascii_vector` for the same reason? They are also two words.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:140&gt;
