[GRASS-dev] [GRASS GIS] #2410: Python ScriptError
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: ScriptError | Platform: Unspecified
      Cpu: Unspecified |
In trunk Python Scripting Library is used !ScriptError from PyGRASS
source:grass/trunk/lib/python/script/core.py#L36. It was introduced in
r61187 by zarch. In relbr70 is still used it's own implementation of
`ScriptError`
source:grass/branches/releasebranch_7_0/lib/python/script/core.py#L70
which defines attribute `value`. This attribute is accessed on many places
of Python Scripting Library or wxGUI, eg.
             except ScriptError as e:
                 self.errorMsg = e.value
Since `ScriptError` from PyGRASS doesn't have this attribute, it fails
with
   File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python/grass/script/task.py", line 70, in __init__
AttributeError: 'ScriptError' object has no attribute 'value'
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410&gt;
      Cpu: Unspecified |
Comment(by zarch):
Replying to [ticket:2410 martinl]:
`ScriptError`
with
Right I did this change, we can modify ScriptError back to:
class ScriptError(Exception):
     def __init__(self, msg):
         self.value = msg
     def __str__(self):
         return self.value
# --- or alternatively
     @property
     def value(self):
         return self.args[0]
or change the e.value to e.args[0]
The value property seems to be used in:
$ grep --color=auto --exclude-dir={.svn,.git,.OBJ,locale,dist.x86_64
-unknown-linux-gnu} -IrnE "\se\.value"
lib/python/script/task.py:70: self.errorMsg = e.value
gui/wxpython/vnet/vnet_utils.py:80: e = e.value
gui/wxpython/vnet/vnet_utils.py:119: e = e.value
gui/wxpython/psmap/instructions.py:1546: GError(message =
e.value)
gui/wxpython/psmap/instructions.py:1584: GError(message
= e.value)
gui/wxpython/psmap/instructions.py:1717: GError(message =
e.value)
gui/wxpython/mapwin/buffered.py:821: GError(message = e.value)
gui/wxpython/location_wizard/wizard.py:2140: return e.value
gui/wxpython/core/settings.py:48: print >> sys.stderr, e.value
gui/wxpython/nviz/mapwindow.py:1355: message =
e.value)
gui/wxpython/nviz/mapwindow.py:1397: message =
e.value)
gui/wxpython/dbmgr/base.py:93: message = e.value)
gui/wxpython/dbmgr/base.py:1814: message =
_("Loading attribute data failed.\n\n%s") % e.value)
gui/wxpython/dbmgr/base.py:1839: message =
gui/wxpython/wxplot/histogram.py:189: message = e.value)
gui/wxpython/wxplot/scatter.py:195: message = e.value)
Personally I think that we should change the ScriptError class definition.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410#comment:1&gt;
how will this be solved? Then we could start backporting python lib etc to relbr7.
thanks
Cpu: Unspecified |
Comment(by zarch):
r61187 by zarch. In relbr70 is still used it’s own implementation of
ScriptError
which defines attribute value. This attribute is accessed on many places
Since ScriptError from PyGRASS doesn’t have this attribute, it fails
with
File “/opt/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python/grass/script/task.py”, line 70, in init
AttributeError: ‘ScriptError’ object has no attribute ‘value’
def init(self, msg):
self.value = msg
def str(self):
return self.value
— or alternatively
@property
def value(self):
return self.args[0]
-unknown-linux-gnu} -IrnE “\se.value”
e.value)
= e.value)
e.value)
e.value)
e.value)
_(“Loading attribute data failed.\n\n%s”) % e.value)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410#comment:1>
grass-dev mailing list
grass-dev@lists.osgeo.org
I will fix this tomorrow…
Pietro
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:1 zarch]:
definition.
for record - has been fixed in r61959.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: ScriptError
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410#comment:3&gt;
