#2415: Checking date format is missing when inserting record in attribute table
manager
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-releasebranch70
Keywords: database, date | Platform: All
Cpu: Unspecified |
Attribute manager allows to save anything (for example integer) in the
date field but reloading the values fails with error 'Unable to scan
date'. This applies to sqlite but I expect to be similar with other
backends. So some checking should be there before it is actually stored
but I don't know what kind of format is acceptable, it depends on the
backend probably.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2415>
