#2418: t.unregister: "maps"-parameter limited to ca. 5000 maps
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Temporal | Version: unspecified
Keywords: | Platform: Linux
Cpu: Unspecified |
In t.unregister the "maps" parameter seems to be limited to ca. 5000 maps.
I have a strds with ca. 20k raster maps and tried to remove all by piping
the output from t.rast.list to the "maps" parameter in t.unregister. After
some testing I found out that the "maps" parameter works fine with 5000
maps, but with 6000 maps and more I got an "Argument list to long" error.
However, unregistering of all 20k maps worked fine when output from
t.rast.list was stored in a file and then t.unregister`s "file" parameter
used.
BTW, maybe a flag for unregistering all maps in a stds would be useful?
Cpu: Unspecified |
Comment(by huhabla):
Replying to [ticket:2418 sbl]:
maps.
piping the output from t.rast.list to the "maps" parameter in
t.unregister. After some testing I found out that the "maps" parameter
works fine with 5000 maps, but with 6000 maps and more I got an "Argument
This is not a defect, its the os specific limitation of argument lists[1].
used.
The reason for the input file option is the os limit of command line
arguments. So you did exactly the right thing by using it in case of 20k
maps.
Sounds useful indeed, feel free to add it to t.unregister.
