#2419: v.distance: hole considered as nearest area
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.5
Component: Vector | Version: svn-releasebranch64
Keywords: v.distance holes | Platform: Unspecified
Cpu: Unspecified |
The following command line in the NC dataset:
v.distance -p from=comm_colleges to=urbanarea upload=cat,dist
col=to_cat,dist dmin=0.0001
leads to two points (from_cats 15 and 52) to have a hole as nearest area,
leading to to_cat=null. The closest areas should be areas (in grass7 the
found to_cats are respectively 54 and 35).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2419>
