#2424: PyGRASS does not work when GRASS is invoked from outside
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Component: Python ctypes | Version: svn-trunk
Keywords: installation, pygrass, temporal, scripts | Platform: MSWindows 8
Cpu: Unspecified |
When one want to
[http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
work with GRASS without starting it explicitly], it is possible to use
`grass.script` but it is not possible to use `grass.pygrass`,
`grass.temporal` and `grass.lib`.
This might have been discussed on mailing already, anyway the reason is
that the dynamic libraries are not accessible to the current process.
Output on Linux:
File "./run_grass_from_outside.py", line 62, in <module>
from grass.pygrass import vector
File "/opt/src/grass-trunk/dist.x86_64-unknown-linux-
gnu/etc/python/grass/pygrass/__init__.py", line 7, in <module>
import grass.lib.gis as _libgis
gnu/etc/python/grass/lib/gis.py", line 23, in <module>
_libs["grass_gis.7.1.svn"] = load_library("grass_gis.7.1.svn")
gnu/etc/python/grass/lib/ctypes_loader.py", line 55, in load_library
return self.load(path)
gnu/etc/python/grass/lib/ctypes_loader.py", line 71, in load
raise ImportError,e
ImportError: libgrass_datetime.7.1.svn.so: cannot open shared object file:
No such file or directory
Output on MS Windows:
File "<stdin>", line 1, in <module>
File "C:\Anaconda\lib\site-
packages\spyderlib\widgets\externalshell\sitecustomize.py", line 523, in
runfile
execfile(filename, namespace)
File "C:\Users\akratoc\test_grass_standalone.py", line 59, in <module>
File "C:\Program Files (x86)\GRASS GIS
7.0.0beta3\etc\python\grass\pygrass\__init__.py", line 7, in <module>
7.0.0beta3\etc\python\grass\lib\gis.py", line 23, in <module>
_libs["grass_gis.7.0.0beta3"] = load_library("grass_gis.7.0.0beta3")
7.0.0beta3\etc\python\grass\lib\ctypes_loader.py", line 55, in
load_library
7.0.0beta3\etc\python\grass\lib\ctypes_loader.py", line 221, in load
return _WindowsLibrary(path)
7.0.0beta3\etc\python\grass\lib\ctypes_loader.py", line 207, in _init_
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\Anaconda\lib\ctypes\__init__.py", line 443, in LoadLibrary
return self._dlltype(name)
File "C:\Anaconda\lib\ctypes\__init__.py", line 365, in _init_
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 193] %1 is not a valid Win32 application
It is unfortunate that you even cannot import `grass.pygrass.modules`:
from grass.pygrass import modules
For Linux, we have to rely on decision of packagers and a user being able
to manage `~/.bashrc` or environmental variables of the given process.
For MS Windows, the solution would be to allow user to add the variables
to the environment. It seems to me that it is "enough" to add path with
dynamic libraries (`lib` and `extrabin`) and GRASS installation directory
(the one with the `grass*.bat` file) to `PATH` and Python packages
(`etc/python`) to `PYTHONPATH`.
The solution is of course invasive but there is no other way. A lot of
applications just do the same without worrying about consequences. We can
try what Git for MS Windows is doing: giving a choice how git commands and
other tools should be spread into the system (modify or not modify the
`PATH`).
The question of course is what should be the default.
Other question is whether to add to the beginning or the end of `PATH` and
`PYTHONPATH` variables.
Also, there must be a warning (in MS Windows installer) that no other
version of GRASS GIS will work.
The same might apply to other OSGeo or related software. This is
unfortunately unknown. I guess that this option cannot be available in
OSGeo4W installer.
I have no idea about Mac OS X. Which solution would be appropriate there?
Do you have some other ideas how to solve or workaround this issue? Would
it be possible to provide a script/functionality in GRASS GIS which would
put the things to environmental variables and take it away if requested (I
guess that the removal is necessary for standard installation too)? This
could be much more flexible. This might be even applicable to all
platforms although for MS Windows it would be quite different from Linux.
Related:
* #2333 (choose python interpreter during the GRASS installation on
windows)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2424>
