[GRASS-dev] [GRASS GIS] #2426: add r.surf.nnbathy to the core code of GRASS 7.1
Reporter: bhlevca | Owner: grass-dev@…
Priority: major | Milestone: 7.1.0
Component: Addons | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
I find this script much faster and gives better results that
r.surf.contour.
I am not sure if there are licensing problems with nnbathy
(https://code.google.com/p/nn-c/) as it is a MIT license, but my
understanding is that it should be possible.
I recently copied manually the script from the Grass6 add on repositories
into the scripts directory of the Grass7.1 installation directory. I also
compiled nnbathy from the above sources.
The Makefile in the grass7 addons did not work although I had the grass6
addons installed in parallel. Probably that needs fixing as well as a
temporary measure until nnbathy is properly integrated.
It worked flawlessly in grass 7.1. The result of a 6000x 10000 nodes was
given in less than one minute. The r.surf.contour gave me a worse result
in 192 minutes! That's more than 3 hours and that happened only after I
lowered the resolution from res=2 to res=6. With res=1 in the g.region the
r.surf.contour did not advance at all after 2 hours so I had to cancel. In
addition the quality is not so great from r.surf.contour, especially if
you have complex shapes.
I believe many people would benefit from this triangulation (nnbathy)
method rather than using the linear interpolation method of
r.surf.contour.
Please consider of adding r.surf.nnbathy to the main repository.
Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426&gt;
      Cpu: Unspecified |
Comment(by annakrat):
[http://lists.osgeo.org/pipermail/grass-dev/2014-April/068179.html link]
to related mailing list discussion
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426#comment:1&gt;
      Cpu: Unspecified |
Comment(by bhlevca):
I read that.
However, I think that it is better to have a tracked item rather than
discussions on a list, which are more difficult to find and probably lead
nowhere because there is no one assigned to deal with it.
Thanks for the reply. I did my job with it, but using hacks and chasing
information on the net. Having it all in a common place would make more
sense. I thought that by raising the issue it would life easier to many
people.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426#comment:2&gt;
Keywords: nnbathy | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
* cc: lazaa (added)
  * keywords: => nnbathy
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426#comment:3&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:2426 bhlevca]:
From https://code.google.com/p/nn-c/source/browse/nn/LICENSE it doesn't
seems to me that it's MIT licence (?)
repositories into the scripts directory of the Grass7.1 installation
directory. I also compiled nnbathy from the above sources.
Please try out new modules which have been recently rewritten from Bash to
Python by lazaa. You can install them via g.extension
g.extension m.surf.nnbathy
which installs two new addon modules: `r.surf.nnbathy` and
`v.surf.nnbathy`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 martinl]:
sorry, it's MIT licence as visible from https://code.google.com/p/nn-c/
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426#comment:5&gt;
