[GRASS-dev] [GRASS GIS] #2430: v.db.renamecol returns error message "can't find v.db.addcol" and fails
Reporter: jbowers | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.5
Component: Database | Version: 6.4.4
Keywords: | Platform: MSWindows XP
      Cpu: x86-32 |
When I try to rename column in a DBF attribute data base using the wxGUI I
get the error message that v.db.addcol can't be found and the renaming
process can't be finished.
Screenshot attached.
This happens even when I try to rename columns that I added to the
database using v.db.addcol.
Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2430&gt;
